Copy Features from joined layer speed
1132
08-28-2013 10:59 AM
AndrewMoffitt
In model builder, I have a model that takes the iterative table input and joins it to a point (28k count) file using the Add Join tool.
The join happens rather quickly, but the Copy Features takes almost 2 minutes.
If I execute the same series of event from the table of contents, the data export only takes around 10 seconds.
Both are going to a local SSD.
[ATTACH=CONFIG]27064[/ATTACH]
Any ideas as to the what and why for this being so much slower?
DaleHoneycutt
My first response is that Copy Features is being executed once per iteration, so that's what causes the slow-down.  Are you saying that it takes 2 minutes per iteration?
AndrewMoffitt
EDIT: Yes it takes 2 minutes per iteration.
I have since removed the Copy Rows as shown in the original picture.  It was left over from my attempts to see if I could speed up the Copy Features.
Below is the code from a single run-through of the model.
This is iterated for every text file within my input folder.
Succeeded at Wed Aug 28 16:10:36 2013 (Elapsed Time: 0.00 seconds)
Executing (Make Feature Layer): MakeFeatureLayer C:\3111\postrun\17_sal\GIS\Mesh_Nodes.shp Mesh_Nodes_Layer # # "FID FID VISIBLE NONE;Shape Shape VISIBLE NONE;NodeID NodeID VISIBLE NONE;Easting Easting VISIBLE NONE;Northing Northing VISIBLE NONE;Z Z VISIBLE NONE;Existing Existing VISIBLE NONE"
Start Time: Wed Aug 28 16:10:36 2013
Executing (Iterate Tables): IterateTables C:\3111\postrun\17_sal\GIS\Tables # # NOT_RECURSIVE
Executing (Make Table View): MakeTableView C:\3111\postrun\17_sal\GIS\Tables\35_45ty1_y3jul_sal_avg.txt 35_45ty1_y3jul_sal_avg_View # # "Field1 Field1 VISIBLE NONE;Field2 Field2 VISIBLE NONE"
Executing (Add Join): AddJoin Mesh_Nodes_Layer NodeID 35_45ty1_y3jul_sal_avg_View Field1 KEEP_ALL
Executing (Copy Features): CopyFeatures Mesh_Nodes_Layer C:\3111\postrun\17_sal\GIS\EntireMeshNodes\35_45ty1_y3jul_sal_avg_Nodes.shp # 0 0 0
Succeeded at Wed Aug 28 16:13:11 2013 (Elapsed Time: 2 minutes 35 seconds)
Executing (Remove Join): RemoveJoin Mesh_Nodes_Layer #
Start Time: Wed Aug 28 16:13:11 2013
Succeeded at Wed Aug 28 16:13:11 2013 (Elapsed Time: 0.00 seconds)
