Set the dojo data grid table size
4051
07-16-2013 07:13 AM
GyeyoungChoi
I'm using dojo data grid for my search results.
but it stretched out longer that it should be.
can anyone tell me what how to set the size for the table?
[ATTACH=CONFIG]25969[/ATTACH]
Thank you.
JonathanUihlein
There is not enough information here to help troubleshoot the actual problem so can you replicate the issue in a JSFiddle?
If you are using a standard dojo data grid, have you checked the Dojo API?
Also, have you looked into dgrid? http://dojofoundation.org/packages/dgrid/
GyeyoungChoi
I should have post code as well, my bad.
        store = new dojo.data.ItemFileReadStore({ data:data });
  dojo.style(dojo.byId("grid"), "width", "280px");
  dojo.style(dojo.byId("grid"), "height", "150px"); //obviously this was not working
  var grid = dijit.byId('grid');
  grid.setStore(store);
  grid.resize();
        autoWidth: true;
        autoHeight: true;
        map.centerAndZoom(center, zoom);
<div class ="toggle" id="menu_subA">Enter building number, name and abbreviation<br>
<input type="text" id="searchField" size="30" value="" /><button data-dojo-type="dijit.form.Button"  onClick="doFind();" value="Search">Search</button>
<table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'1', rowSelector:'10px'">
      <thead>
        <tr>
          <th field="Number" width="50">Num</th>
          <th field="Abbrev" width="50">Abbr</th>
          <th field="CampusCode" width="50">Camp</th>
        </tr>
      </thead>
    </table>
  </div>
JakeSkinner
Esri Esteemed Contributor
Hi Gyeyoung,
Try setting the height of your div to limit the number of rows returned.  Ex:
<div class ="toggle" id="menu_subA" style="height:55px;">Enter building number, name and abbreviation<br>
              <thead>
            <tr>
            </tr>
              </thead>
        </table>
</div>
AdrianMarsden
Honored Contributor
Hi
Is it OK to put a link to a similar issue that I raised a few days ago - http://forums.arcgis.com/threads/88405-Dynamically-created-datagrid-inside-ExpandoPane-sizing-issues - I've had allsorts of issues with a datagrid inside a expandopane.  every time the pane collapses it re-sizes the datgrid away from the definition - sounds very similar to the OPs problem
Cheers
ACM
