3D Buffer in Python - CE?
3099
07-05-2013 03:55 AM
CarlBester
Hi all,
I want to create pipe-models from graphs in CE.
I am able to generate the "pipe" models for the straight segments using a .obj asset. But as soon as the graph curves the bend does not align with the rest of the network. Is there a way to do this?
[ATTACH=CONFIG]25735[/ATTACH]
I then wondered if it would be possible to create a 3D buffer of the selected line segments (similar to 3D Analyst), using Python in CE resulting in a multipatch which I can add afterwards. Any advice?
Carl
Tags (3)
MatthiasBuehler1
Hi Carl,
Instead of inserting directly, first use the comp(f) to split into each polygon of the shape.
Ok ?
Matt
MatthiasBuehler1
Hi Carl,
Ok ?
Matt
CarlBester
Hi Matt. Worked like a charm! Thanks!;)
