How to define metaclass for a class that extends from sqlalchemy declarative base ?
1069
07-02-2013 08:38 PM
VenKarri
I use: Python 2.6 and sqlalchemy 0.6.1
This is what I am trying to do:
from sqlalchemy.types import (
    Integer,
    String,
    Boolean
from sqlalchemy.ext.declarative import declarative_base
Base = declarative_base()
class SampleMeta(type):
    def __new__(cls, name, bases, attrs):
        attrs.update({   'id': Column('Id', Integer, primary_key=True),
                    'name': Column('Name', String),
                    'description': Column('Description', String),
                    'is_active': Column('IsActive', Boolean)
        return super(SampleMeta, cls).__new__(cls, name, bases, attrs)
class Sample(Base):
    __tablename__ = 'Sample'
    __table_args__ = {'useexisting': True}
    __metaclass__ = SampleMeta
    def __init__(self, id, name, description, is_active):
        self.id = id
        self.name = name
        self.description = description
        self.is_active = is_active
    def __repr__(self):
        return "<(%d, '%s', '%s', %r)>" % (self.id, self.name, self.description, self.isactive)
And the error I am getting is this:
TypeError: Error when calling the metaclass bases
    metaclass conflict: the metaclass of a derived class must be a (non-strict) subclass of the metaclasses of all its bases
Now, if I do the same thing above by using
class Sample(object)
instead of
class Sample(Base)
it works absolutely fine.
I need to update the attributes of the class dynamically. So, I will be using dynamic attribute and column names. And I need the above piece code to work in order to be able to get there.
Please help
Tags (3)
MatthiasBuehler1
CityEngine uses Jython, not native Python, so I recommend you search first if this SqlAlchemy thingy is supported in Jython.
Sorry, cannot help further .. good luck.
M.
