How to stop Map from rotating using JS API
1319
05-31-2013 01:20 AM
ShashankA
Hi
I have simple map. I'm adding a layer of type 'ArcGISTiledMapServiceLayer' and displaying 'https://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer' map.
No when I pan the map to Left or Right side a new map starts to appear on the screen as if they are endless of maps on the screen which come up as I keep on pan the map to Right or Left sides.
I don't want my map to display another map on the screen. Please refer to the Screenshot of what I mean.
In the screen shot you can see that when I pan right bringing Australia in to the middle of my screen I see SouthAmercica slowly coming in to the screen from right hand side of the map.
I want this behaviour to be stopped. Is their any way to stop this behaviour of the map?
Update:
Currently I'm using 3.4 version of Js API. When I user earlier versions of the Js API like 2.8 I get the functionality what I want i.e., new map does not creeps out from other side of the map when user panns the map to one side of the map.
Thanks in advance.
MarkHoover
This is a property you can configure when you create your map object.  It's an option (the second, optional parameter for a map object).  From the documentation:
<Boolean> wrapAround180 When true, supports continuous pan across the dateline. Wraparound is supported in the following cases:
    Map spatial reference is WGS84 or Web Mercator
    The tiling scheme is either the pre-9.3 ArcGIS Online (4326) tiling scheme or ArcGIS/Google Maps/ Bing tiling scheme.
    Dynamic services must be version 10 or greater.
At version 3.1 the default value is true. For versions earlier than 3.1 the default value is false.
http://developers.arcgis.com/en/javascript/jsapi/map.html#map1
MarkHoover
