Title Name not displaying in Web map Print Template output...
867
04-25-2013 01:04 AM
RameshPodugu
Hi All,
I am unable to get the custom Title Name given by the user in Webmap (Shown in attached image) for Print out.
I am using ArcGIS server 10.1, Javascript 3.3 version.
I was created a python script to access the Map Title and other parameters. Except Map title other parameters are reflecting.
Below is my Print function i am using.
var objPrintButton;
        function print() {
            //debugger;
            objPrintButton = document.getElementById("exportMapBtn");
            objPrintButton.outerText = "Exporting..";
            var given_MapName = mapTitle.value;
            var layout = dijit.byId("mapLayout");
            var selectedValue_layout = layout.value;
            var format = dijit.byId("exportType");
            var selectedValue_format = format.value;
            var selectedValue_georef_info;
            if (incGeoRef.checked == true)
                selectedValue_georef_info = "True";
            else
                selectedValue_georef_info = "False";
            var incAttr;
            if (incAtt.checked == true)
                incAttr = "True";
            else
                incAttr = "False";
            var legendLayer = new esri.tasks.LegendLayer();
            legendLayer.layerId = "JT_Buildings_A4";
            legendLayer.subLayerIds = [];
            if (RoadCenterLine.checked == true) {
                legendLayer.subLayerIds.push(0);
            if (Buildings.checked == true) {
                legendLayer.subLayerIds.push(1);
            //debugger
            var template = new esri.tasks.PrintTemplate();
            template.format = selectedValue_format;
            template.layout = selectedValue_layout;
            template.layoutOptions = { "MapTitle": given_MapName, "legendLayers": [legendLayer], "scalebarUint": "Meters", "Attribute_Info": incAtt };
            template.prserveScale = true;
            params.template = template;
            params.extraParameters = { Georef_info: selectedValue_georef_info };
            printTask.execute(params, printComplete, printError);
let me know any more details required.
Advance thanks for early reply
[ATTACH=CONFIG]23755[/ATTACH]
