AGSJS Table of Contents (TOC) Widget for ArcGIS problem
1885
02-07-2013 05:45 AM
MartynSmith
First of all I'd like to thank the creator of this great table of contents widget.  This is something that should be a default part of the API but for some reason still is not.
My issue is that I have a dynamic map service with three main grouped layers.  The top grouped layer has initialVisibility=true, and the bottom two are off by default.  When I toggle the checkboxes for the bottom two layers however, it does not turn them on.  Can anyone suggest a fix for this?
agsjs toc widget v2.04
esri jsapi v3.2
Thanks for any help.  Attached is a screen capture of my issue:
[ATTACH=CONFIG]21550[/ATTACH]
KevinMacLeod1
Marty, I agree, this is a great piece of work, thanks to Nianwei Liu! I also highly recommend to ESRI to include this going forward (at least as an option to enable) in their templates, e.g. Basic Viewer.
I'd recommend you give us a link to your site and relevant pieces of code in order to take a look at the issue.
Also this may help... Nianwei in fact posted an example of this AGSJS TOC integrated in to ESRI's Basic Viewer, referenced in this thread: http://forums.arcgis.com/threads/75725-BasicViewer-with-TOC  Perhaps this site or code will meet your requirements? As he directed, use Firebug to get the relevant scripts. Also, one other tip: I put multiple instances of this AGSJS widget into AccordionPanes and it works great. Just fyi.
JeffPace
remember checking the box turns the GROUP on, but does not change the sublayers.  Are the sublayers on ?
can you expand the bottom two? If they are all unchecked, checking the box does nothing.
