Calcuating nearest point to a given point.
1556
12-07-2012 07:21 AM
NadeemQazi
[ATTACH=CONFIG]19790[/ATTACH]I am new in Geo Analysis. Please refer to attach image to understand my problem . I have two layers as shown in table of the content in the map attached. The one named as sewered areas has following fields :
FID,Shape,County,Name,AreaRef,AreaHect,Source,Audit Name,Audit Date,comment.
The one that is named as tank has following fields.
FID,Shape,Join_Count,Join_Cou_1,BUILDING_I,ADDRESS_PO,ED_ID,BUILDING_U,EAST,NORTH,
DERELICT,VACANT ,INVALID,Name, Shape_Leng,Shape_Area,COUNTY,NAME_1,AREA_REF,AREA_HECT, SOURCE,AUDIT_NAME,AUDIT_DATE, COMMENTS,NEAR_FID,NEAR_DIST.
the third layer called roads has following fields
FID,Shape,ROUTE_NO,LINE,Shape_Leng,RD_TYPE
I already have done it by drawing a single line between the point in sewered area and septic tank and measure the length of that line to give me the distance. however What I want is that when I click any where in my sewered areas layer i want to determine the distance between this point and all the tanks in for example 1 km radius. and i also want to check whether this tank is on the road or  not.
Any suggestion or direction to start the work?
EricRice
See the Generate Near Table tool.
Best,
Eric
