could you please help me to solve the problem with importing las file into ArcMap.
I have used the Conversion Tool- From File- Las to Multipoint (the 3D Analyst Tool) to convert the las file into shp.
As a result I have received a dataset that consists of 8 smaller datasets.
The fact is that there is no possibility to define the values of X,Y coordinates for each point
(by using the Add XY Coordinates function-the Data Management Tools);it is possible to do it only for each of the created smaller datasets.
Is it possible to import las file into ArcMap and then define the values of X,Y coordintaes for each point without creating "blocks" of data?
Thanks for your help,
Malgosia
