Popup Panel Widget Customization
8834
23
04-21-2016 07:15 AM
NatashaManzuiga
Hi all,
I'm trying to set a different behavior of the Popup Panel Widget on map click for each layer.
For a particular layer, I need to retrieve data from a webservice passing a field value as parameter.
Is it right what I'm trying to do or you think I have to move this code somewhere else?
at the moment the line 10 gave me an error:
TypeError: this.own is not a function
startup: function () {
    this.inherited(arguments);
    var map = this.map;
    LayerInfos.getInstance(map, map.itemInfo).then(lang.hitch(function(operLayerInfos) {
    operLayerInfos.getLayerInfoArray().forEach(function(layerInfo) {
            if (layerInfo.title == 'Map') {
                var layerId = layerInfo.id;
                console.log('layer ID = ', layerId);
                var layer = map.getLayer(layerId);
                this.own(on(layer, "click", lang.hitch(this, this.onMapClick)));
    this.displayPopupContent(this.popup.getSelectedFeature());
onMapClick: function(event) {
//I want to disable the normal behavior of the click (retrieve data and populate the Popup Panel widget with my customized content)
  var queryTask = new QueryTask('*Service URL*');
  var query = new Query();
  query.returnGeometry = true;
  query.outFields = ['*'];
  query.geometry = event.mapPoint;
  queryTask.execute(query, lang.hitch(this, this.showResults));
showResults: function(results) {
  var resultItems = [];
  var resultCount = results.features.length;
  for (var i = 0; i < resultCount; i++) {
      var featureAttributes = results.features.attributes;
      var URL = "theWebServiceUrl" + featureAttributes.NAME;
    //and I want to pass this URL to call it with through esri/request and retrieve data and then populate the PopUp Panel
Naty
Tags (1)
NatashaManzuiga
Many Thanks Robert,
I edited your code as follows:
this.own(on(this.popup, "selection-change", lang.hitch(this, function () {
   var gra = this.popup.getSelectedFeature();
   if (gra){
var layer = gra.getLayer();
console.info(layer.name);
   //domConstruct.destroy("testnode");
if(layer.name === "Map"){
var URL = "../test.json?" + gra.attributes.NAME;
console.log("../test.json?" + gra.attributes.NAME);
var row = domConstruct.toDom('<tr id="testnode"><td>bar</td><td>'+ URL+'</td></tr>');
domConstruct.place(row, this.actionsListDiv);
return;
It works, but if I make a search through the Search Widget the console says "undefined" at line: "console.info(layer.name);" ..
Thanks again,
Naty
RobertScheitlin__GISP
Naty,
  So just check if the layer is not null then (line 5):
  if (gra){
    if(layer && layer.name === "Map"){
      return;
NatashaManzuiga
Robert, that's fine... but after the search executed by the search widget, the Popup Panel doesnt' show me what I added in this line
because var layer is undefined and I dont know why...
Naty
Naty,
  I don't know your workflow like you do. You will have to determine some other means of checking if the graphic belongs to your Map layer then. Maybe it has a certain attribute that you can check for to determine if it is the right layer to work with?
NatashaManzuiga
Robert, my goal is to add webservice (JSON) data at the Popup Panel.
Now it works fine if I click on the map and I'm able to get a field value and use it as parameter of the webservice (JSON).
But if I make an alphanumerical search by the Search Widget, nothing happens because the handle event inside the Popup Panel
(this.own(on(this.popup, "selection-change"....)
give me back nothing at this line :
Naty
Naty,
So you are saying that you do a search in the search widget and click on a search result and the map displays a popup and zooms the map and the "selection-change" event has a null for this.popup.getSelectedFeature();?
NatashaManzuiga
Yes
Naty,
  The search Widget adds the search result to the maps graphics layer and thus does not have a layer property.
Here is what I think you should do:
          if(gra){
            console.info(gra);
            if(layer && layer.name === "map"){
              var URL = "theWebServiceUrl" + gra.attributes.NAME;
              console.info(URL);
              //this will prevent it from going to the function that displays the popup info
              return;
            }else if(gra.attributes.hasOwnProperty("yourspecificfieldname")){
              var URL2 = "theWebServiceUrl" + gra.attributes.NAME;
              console.info(URL2);
              return;
On line 12 you will have to determine if this is a search result graphic and if so is it one you are interested in. The problem is you are using such a common field name "NAME" so many graphics beside your specific layer use that field name.
NatashaManzuiga
PERFECT!!!!!
Thanks, Thanks, Thanks,
Naty
NatashaManzuiga
Robert,
Now, I want to modify the default popup on "selection-change" instead of in the popuppanel.
Where should I change the code to capture this event?
Naty
