Popup Panel Widget Customization
8938
23
04-21-2016 07:15 AM
NatashaManzuiga
Hi all,
I'm trying to set a different behavior of the Popup Panel Widget on map click for each layer.
For a particular layer, I need to retrieve data from a webservice passing a field value as parameter.
Is it right what I'm trying to do or you think I have to move this code somewhere else?
at the moment the line 10 gave me an error:
TypeError: this.own is not a function
startup: function () {
    this.inherited(arguments);
    var map = this.map;
    LayerInfos.getInstance(map, map.itemInfo).then(lang.hitch(function(operLayerInfos) {
    operLayerInfos.getLayerInfoArray().forEach(function(layerInfo) {
            if (layerInfo.title == 'Map') {
                var layerId = layerInfo.id;
                console.log('layer ID = ', layerId);
                var layer = map.getLayer(layerId);
                this.own(on(layer, "click", lang.hitch(this, this.onMapClick)));
    this.displayPopupContent(this.popup.getSelectedFeature());
onMapClick: function(event) {
//I want to disable the normal behavior of the click (retrieve data and populate the Popup Panel widget with my customized content)
  var queryTask = new QueryTask('*Service URL*');
  var query = new Query();
  query.returnGeometry = true;
  query.outFields = ['*'];
  query.geometry = event.mapPoint;
  queryTask.execute(query, lang.hitch(this, this.showResults));
showResults: function(results) {
  var resultItems = [];
  var resultCount = results.features.length;
  for (var i = 0; i < resultCount; i++) {
      var featureAttributes = results.features.attributes;
      var URL = "theWebServiceUrl" + featureAttributes.NAME;
    //and I want to pass this URL to call it with through esri/request and retrieve data and then populate the PopUp Panel
Naty
Tags (1)
RobertScheitlin__GISP
Naty,
  What version of WAB are you talking about?
NatashaManzuiga
Hi Robert,
at startup of my widget I added this code
on(this.map.infoWindow, 'selection-change', lang.hitch(this, function() {
        this.replacePopUp();
I still have to understand this:
1) it seems like I 'm replacing the infoWindow content ....using the call this.map.infoWindow.setContent('bla bla bla') in replacePopUp....cause if I use a break before setContent in google chrome developer, I see the default content of the infoWindow.
Naty
Naty,
That is exactly what you are doing.
NatashaManzuiga
Robert, yes it is.
But can I replace the infoWindow content..before the infoWindow default content is set and displayed?
Naty
