Google Street View Widget 2.1 - 08/29/16
92877
244
12-31-2014 11:01 AM
All after much back and forth with different people and what now seems to be legitimate email traffic with the Google Maps API Team. It is now apparent that this widget does NOT conform to the Google Maps API Terms of Service. Due to this fact, this widget download will be removed and the live preview site will be un-accessible.  It is my recommendation that all users of this widget immediately remove the widget from their WAB site and discontinue use of this widget. The only way it seems currently to be compliant with the TOS is to not have a (non-Google) map visible at all in the app which is of no use at all to us esri users. I find it hard to understand how the Worlds leader in GIS technology and Google can not come to terms on the use of StreetView panoramas with esri basemaps, but it is what it is. So after years of this widget being used by hundreds of users around the world we must say good-bye.
Here is another widget for the Web App Builder.
Web AppBuilder for ArcGIS | Help - Google Street View widget
List of the latest enhancements and changes:
  1. Updated for WAB 2.1
List of older enhancements and changes:
  1. Widget no longer open the street view html window automatically on open.
  2. Prevent popup check from firing multiple times.
  3. Removed sensor portion of the StreetView code as Google has depreciated it.
  4. Minor configuration UI changes.
  5. Widget code updated to work with all the new themes and their style colors.
  6. Fixed issue with maps whose spatial reference was not 4326 or 102100
Features:
  • This widget conforms to the Google Terms of Use (TOS) agreement
  • Widget allows configuration of Google Street View Panorama Options
  • Widget provides drag and drop support
  • Widget provides graphical feedback on the map when changes are made to the Street View Panorama window
  • This widget displays the Google Street View Panorama in a popup browser window as to not violate the Google TOS agreement
Comments
deleted-user-RUEqqvNTOoQf
Hi Robert,
Thank you for putting this widget together. I find it very useful in all of my applications!
I have one question about this widget. When I click on this widget in my launched application. It will pop up the widget window along with the window for the actual street view.
I remember it didn't do that before(I could be wrong though). It used to have the widget window pop up and when you drag the little golden man onto the map, then the street view window would pop up.
I tried downloading the widget again and reinserting the widget into my application. Same thing happened.
This is not a big deal, it works fine when I just close the street view window and drag the golden man onto the map where I want. But I am wondering if you have some tips for me that can help avoid having the street view window pop up right when the widget is clicked.
Thank you very much for your time and kind attention. Have a wonderful day!
Sunny Shang
GIS Analyst
Scott County, Iowa
RobertScheitlin__GISP
Sunny,
  I don't remember it not opening the street view window automatically when started but if you do not like that then there is a simple code change you can make (see where I commented out the else portion of the if statement below):
onOpen: function(){
        this.attempts = 0;
        if(this.graphicsLayerGSV){
          this.graphicsLayerGSV.setVisibility(true);
        if(this.hideStreetviewWindowWhenMin){
          if(this.popupsBlocked){
            var qMessage = new Message({
              type: "error",
              titleLabel: this.nls.popupblockererrortitle,
              message: this.nls.popupblockermsg,
              buttons: [{
                label: this.nls.ok,
                onClick: lang.hitch(this, lang.hitch(this, function(){
                  qMessage.close();
                  PanelManager.getInstance().closePanel(this.id + "_panel");
          // else{
          //   this.openSVwin(this.wBGColor,this.noSVImageAvailableMsg,this.gAPIKey,this.gAPIClientID,this.windowWidth,this.windowHeight);
Thanks a lot for your timely response. It worked! Thank you very much!
Sunny
On Mon, Apr 11, 2016 at 10:29 AM, Robert Scheitlin, GISP <geonet@esri.com>
LianaSmith
Robert,
In my case when I do the change in the code. It doesn't work. I get en error in the Application. Could you please check if I am doing it right? Thanks!!!
Diana,
  I don't see in your code where you have commented out lines 131-133 like mentioned earlier.
LianaSmith
Sorry, Robert. Wrong screenshot...
Diana,
  Can you show me the browser console error?
LianaSmith
GeorgeKatsambas
Which file needs the "else" commented out (line 131) for streetview popup?
It is the Widget.js. If you switch to my 2.0.1 version then you do not have to worry about this, and other performance fixes were made.
GeorgeKatsambas
If i download 2.0.1 do i add it to my widgets folder on server as well as my WAB folder
George,
  If you are using WAB 2.0 then get my new 2.0.1 version of the widget and add it to the stemapp widgets folder and the server/apps/[App#]/widgets for any of your apps that use the Streetview widget.
GeorgeKatsambas
Thanks Robert, on my Ipad I still get the error that the request was rejected by the HTTP Filter so as you told me before I will have to condense the messages in the strings.js file as our IT department has changed something.
George,
  Ya, sorry I can't do much to handle when IT depts do crazy stuff like that.
by Anonymous User
Not applicable
Robert Scheitlin, GISP​  -- it was so great to meet you and Larry at the Developer Conference.
I have been more of an Analyst of late but am now returning to the dev world.  So, something curious has happened apparently with the Google API and an interaction with your widget.
When I go to place the Google Peg Man from your widget onto the screen, the widget shows Street View but all in weird triangles and is all messed up. This happens in your current 2.01 demo as shown in the Snip below and to all my existing WAB Sites that I built with Esri WAB 1.2 and with your widget, version 1.2 of Street View widget.
However.. It very curiously works perfectly in Internet Explorer and MS Edge. Just not Chrome or Firefox. How ironic for Street View to only work in IE.
The thing is, it used to work fine. Nothing changed on my end. I am guessing Google did something to their API perhaps?
Anyhow, is anyone else seeing this? Below is from Chrome in your demo and my 1.2 site with your 1.2 widget and WAB 1.2.
I do see a warning in console about no API key but it always worked fine before without one. Do I need to get one? I also see a warning about 'SensorNotRequired' not sure what that is but it doesn't sound relevant.
Hi Kevin,
We bumped into the same issue with chrome, and the solution was found here. Google Groups
Best,
Sunny
Kevin,
  Have you tried again? I just tested 2.0.1 and 1.3 on my sites and they work fine.
by Anonymous User
Not applicable
Yiqing Shang​  Robert Scheitlin, GISP
Yiqing many thanks! That fixed it, works perfectly now!  I guess this is the double-edged sword of 'evergreen' browsers and software. Thanks again, all set now! Ya'll are the best.
Note also...For whatever reason, it didn't seem to affect my implementation on MapViewer - Savannah Area GIS though, which functions slightly differently.
IanGrasshoff
Hey Robert,
I love your Google Street View widget!  I hope you don't mind, but I took the liberty to enhance the widget with the ability to display the "Google Street View" coverage layer within the map window.  I found it difficult for users that weren't aware of Google Street View Coverage areas.  In my case I work for a rural county and we only have Street View on major highways.  The enhancement that I made helps solve this problem.
My solution is not perfect as far as the Google Map Tile alignment, but it's close enough.  Also, the Web Map MUST be in Web Mercator coordinate system.  Also, there is a little bit of visual disruption as the Google Map Layer loads after the Esri map finishes.
Below this a link to the widget demo.  I haven't tested it extensively...so their could be bugs.  I would be happy to throw the code on GitHub or GeoNet if you want.
Widget Demo
BarnabyRockwell
Very well done, Ian.  Your widget shows users where they can drop the man.  Could be very useful when a basemap (like Imagery) not showing roads is used.  Could you update your demo app to include the esri Imagery basemap?
Cheers,
Barnaby
IanGrasshoff
Thanks for the feedback.  I updated the demo showing the Esri imagery basemap.
BarnabyRockwell
Fantastic!  It works perfectly.  This is a great enhancement of Robert's widget.  Without it, users have to load a basemap containing streets (Open Street Map, esri Streets) to know where to drop the man, and even then can waste time dropping the man on streets not covered by Google Street View coverage.
Most WAB apps already use Web Mercator to get the basemaps to display as fast as possible, I expect.
IanGrasshoff
Right...I noticed that users were getting frustrated dropping peg man all over the map and not getting street view.  This solves that problem!  Their is a minor tile alignment issue at lower zoom levels, but they still get the idea!
Ian,
  I like it. Yes I would be interested in you posting the code for this. I will need to investigate Terms of Use for this and see if I can work some more on the alignment. When using Google Maps this layer is only shown when dragging the pegman so this would fix a lot of the visual disruption when panning and clean the map up.
IanGrasshoff
I also thought about only only the Google Street View Layer when dragging pegman.  Yes, the terms of service....I thought about that after working on the enhancement, doh.  Maybe when we drag pegman the Esri map disappears completely and only shows Google Maps?  When he gets dropped the Google Map disappears and Esri map is back?  The alignment issue won't be noticeable then..
Message me at ian.grasshoff@co.waupaca.wi.us​ and I will send you my code.  I would be happy to work on it with you.
BarnabyRockwell
An option to disable the Google Street View coverage visibility would be good for some apps, I imagine...
IanGrasshoff
Agreed, I just added an option to the widget config that allows you to turn on/off the street view coverage map option.
IanGrasshoff
Robert Scheitlin, GISPBarnaby Rockwell
Morning,
I updated the Widget so it only displays the Google Map Street View Coverage all by itself.  Combining the Esri Map with Google Map most likely violates Google Maps Terms of Service.  While it was very useful to mash the two maps together..it's still very workable to only display the Google Map.  Once the user drops pegman, the Esri map switches back on and Google switches off.
Updated Street View2 Demo
BarnabyRockwell
Lookin' good!
BradfordFolta
Using Web Appbuilder 2.0 and the most recent download of the Street View Widget - everything seems to work fine in Internet Explorer and Chrome. However in Firefox I'm getting an error message when the Street View Popup window opens: "initialize malformed URI sequence" and the window does not display the Google Street View.  Any idea what makes this different in Firefox only? The exact same web app page loads and the Street View app works fine in IE and Chrome, so it's just Firefox that has an issue.
Here's a screenshot of the error message: malformedURI.jpg - Box
...and here's the URI in the popup window that will not load - Google Street View
David,
  I am not sure what is going on but the "®" is not getting encoded properly as %C2%AE in your url. Yours only has %AE. Go into the [install dir]\server\apps\[app#]\widgets\StreetView\nls folder and open the strings.js and check and see if your nostreetviewimageavailablemsg is:
nostreetviewimageavailablemsg: "No Street View Image Available<br>or you have not yet dragged the Google® Street View man<br>onto the map to set your location.", If it is and you still get the issue then remove the ® from after Google and try again.
BradfordFolta
Hi Robert,
Sure enough – removing that copyright symbol from the text message in
strings.js did the trick – now it works fine in all browsers! BTW this is
a HUGE help having this Street View app available for using in the Web
Appbuilder – Thank you so much, really appreciated!
-David Booth
Sent: Tuesday, May 17, 2016 9:15 AM
To: David Booth
Subject: Re: - Google Street View Widget
2.0.1 - 04/21/16
GeoNet <https://community.esri.com/?et=watches.email.document_comment>
Google Street View Widget 2.0.1 - 04/21/16
new comment by Robert Scheitlin, GISP
<https://community.esri.com/people/rscheitlin?et=watches.email.document_comment>
View
all comments on this document
<https://community.esri.com/docs/DOC-2991?et=watches.email.document_comment#comment-23174>
ErnestoCarreras3
Robert, I will like to get some information on how you handle the development cycle of your widgets when Esri updates Web App Builder. Can we chat via private message?
AlexJohnson
Robert - Nice Widget! I'm playing around with it in Web AppBuilder Developer Editing verion 2.0, and get:
RequestError: Unable to Load //utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer/project?f=json&outSR=4326&inSR=102642&geometries=%7B%22geometryType%22%3A%22esriGeometryPoint%22%2C%22geometries%22%3A%5B%7B%22x%22%3A7129879.578318954%2C%22y%22%3A2101040.8799832524%2C%22spatialReference%22%3A%7B%22wkid%22%3A102642%2C%22latestWkid%22%3A2226%7D%7D%5D%7D
That URL works fine in a browser window, returning the projected geometry. I'm suspect I'm missing something obvious... Ideas?
Alex,
  Are you running this from http or https? I have not seen this exact issue before.
AlexJohnson7
Robert - Thanks for the reply; I'm running it from https.
-Alex
Alex,
     I know of others running https and they are not having any issue. So I am not sure what to tell you.
ZhujingXia
Robert,
I used this widget in Web AppBuilder 2.0 for Developer version. Most time I will get error message through the street view dialog box after I click on the map, some times I could get the street view.
The message said that "Oops! Something went wrong, This page did not load Google Maps correctly. See the javascript console for technical details."
Do you know what is wrong?
Zhujing,
  Most of the time this happen when the Google API key is not configured correctly. Try deleting the API key altogether and test again.
ZhujingXia
Robert,
I fund that the street view will show up for few seconds and then I will see the error message. I nee close the Street View dialog box and use the walking man to click on the map, the street view would show few seconds again then the error message will show up. why it happened like this?
Thanks
Zhujing
ZhujingXia
Robert,
I removed the GoogleAPIKey from the config.Jason file. But the error message still shows up.
Zhujing
Zhujing,
What browser are you using? How does your browser do using the Live preview site at the top of this page?
ZhujingXia
Robert,
I used both IE and google chrome. It performance the same thing. But the Live Preview site works fine.
Zhujing
Zhujing,
  So it has something to do with your Google API Key and the url you used to register that key then. So I can not be of more help.
ZhujingXia
Robert,
I just used the widget, did not change the google API Key or the URL to register that key. So I need to get my own google API key and register it?
Thanks
Zhujing
Hmm, I take it you did not read the help document them...
ZhujingXia
Robert,
It worked. Thanks.
Zhujing
LianaSmith
Robert,
Help document link does not work. Thanks
Liana,
   The help doc link on the download page works great. Which help link are you referring to?
LianaSmith
Now it does.
Version history
Last update:
‎12-31-2014 11:01 AM
Updated by:
