WABDev 1.19
Theme: Launchpad
I'm looking for how WAB refers to the WidgetManager.js file when a page is initially loaded. Is there a specific .html file that refers to it like,
<script src="WidgetManager.js" ></script>
Thanks for any info!
So if you look at the source tab and search for WidgetManager.js file (after loading your WAB app) you will see "WidgetManager.js?wab_dv=2.20" so the easy way to manage no caching is to change the "deployVersion = '2.20';" in the env.js file each time you make some code changes. For example
That js file is loader inside the configLoader.js, configManager.js, main.js, etc files. There is not a script tag that loads it.
I see. The issue I have is I included a bit of code in the WidgetManager.js to attempt to deal with caching. Anytime I redeploy a WAB with custom widgets this cache issue rears its head and telling users to clear browser cache or use incognito window (both work) is not an acceptable solution.
I updated the _tryLoadWidgetConfig function in the WidgetManager.js with this,
_tryLoadWidgetConfig: function (setting) {
var def = new Deferred();
//need load config first, because the template may be use the config data
if (setting.config && lang.isObject(setting.config)) {
//if widget is configurated in the app config.json, the i18n has beed rocessed
def.resolve(setting.config);
return def;
} else if (setting.config) {
if (require.cache['url:' + setting.config]) {
def.resolve(json.parse(require.cache['url:' + setting.config]));
return def;
var configFile = utils.processUrlInAppConfig(setting.config);
// The widgetConfig filename is dependent on widget label,
// IE8 & IE9 do not encode automatically while attempt to request file.
var configFileArray = configFile.split('/');
configFileArray[configFileArray.length - 1] =
encodeURIComponent(configFileArray[configFileArray.length - 1]);
configFile = configFileArray.join('/');
//Append date to ensure you get the latest json file
configFile += "?currentVersion=" + Date.now();
return xhr(configFile, {
handleAs: "json",
headers: {
"X-Requested-With": null
} else {
return this._tryLoadResource(setting, 'config').then(function (config) {
//this property is used in map config plugin
setting.isDefaultConfig = true;
return config;
},However, the WidgetManager.js file itself is being cached. So I hoped to apply something to whatever loaded this to force a new version to be loaded each time.
Ok thank you I will give that a go!
Robert this looks like it will be the winner on this issue. I had a strange result when I tested but since I redeployed again the initial testing is promising and just need users to validate.
Thanks for the tips.
I took one of our dev WABs with custom widgets and updated the env.js file line #83 with your suggestion:
deployVersion = '2.19.20210709';
I added the Bookmarks widget to the WAB app, redeployed it and navigated to the app and this is what shows when it opens:
Inspecting the env.js that got loaded, line 83 shows the cached version not what I changed it to.
If I use incognito browser window (Chrome) it opens just fine with the Bookmarks widget!
I then tried to update the index.html with this,
<script type="text/javascript" src="env.js?1"></script>Which seemed to do something! I can see the Bookmarks widget and I didn't get the error as before but now the WAB loads weird like top of the page is split.
In the index.html file there are script tags that call the init.js file that loads most of the WAB js files.
