Web AppBuilder Custom Widget - Selecting feature after applyEdits
4276
10
05-31-2019 08:26 AM
MarkEastwood
I am trying to create a custom widget that allows users to copy and paste a record that has the same attributes and geometry. The copy and paste part of the widget is working but I also want the popup to appear for the newly created feature after it has been added. Originally, the section of code that I am having problems with worked without the popup appearing ...
_copyFeature: function() {
        this.inherited(arguments);
        this.targetLayer.applyEdits([this.featureGraphic], null, null, this._onEditSuccess());
_onEditSuccess: function() {
        this.map.graphics.clear();
        this.map.setExtent(this.map.extent)
        this._postResults("<span style='color:#3ca553;'>Copied " + this.sourceLayer.name + ' Site Number - ' + this.featureGraphic.attributes.site_num + " to " + this.targetLayerName + "</span><br>");
The code I am using to get the popup to appear is below. The problem is, the popup is showing the feature that I am copying not the newly added record.
    this.targetLayer.refresh();
    var query = new Query();
    query.geometry = this.featureGraphic.geometry;
    this.targetLayer.selectFeatures(query, this.targetLayer.SELECTION_NEW);
    this.feature = this.targetLayer.getSelectedFeatures();
    var selectLength = this.feature.length;
    //console.log(selectLength);
    //console.log(this.feature);
    this.feature = this.targetLayer.getSelectedFeatures()[selectLength];
    this.map.infoWindow.setFeatures([this.feature]);
    this.map.infoWindow.show(this.featureGraphic.geometry);
It appears like the edit is not being applied before the _onEditSuccess() is being run. I tried using 'edits-complete' so the _onEditSuccess() would run after the edit was completed but I had no luck. Maybe I am going about this the wrong way. Any suggestions would be appreciated.
MarkEastwood
That worked great, Robert!
I was able to get the desired behavior with the following code updates/additions.
        this.targetLayer.applyEdits([this.featureGraphic], null, null, lang.hitch(this, this._onEditSuccess), lang.hitch(this, this._onEditError));
      _onEditError: function(err){
        console.error(err);
      _onEditFail: function(e) {
        this._postResults("<span style='color:#c13333;'>" + e.name + ": " + e.message + "</span><br>");
      _onEditSuccess: function(adds) {
        query.where = "OBJECTID = " + adds[0].objectId;
        this.targetLayer.clearSelection();
        this.targetLayer.selectFeatures(query, this.targetLayer.SELECTION_NEW, lang.hitch(this, this._onSelectSuccess), this._onSelectError);
      _onSelectSuccess: function(suc){
        this.map.infoWindow.setFeatures([this.targetLayer.getSelectedFeatures()[0]]);
        this.map.infoWindow.show(this.targetLayer.getSelectedFeatures()[0].geometry);
      _onSelectError: function(err){
        console.log(err);
