Web AppBuilder Custom Widget - Selecting feature after applyEdits
4272
10
05-31-2019 08:26 AM
MarkEastwood
I am trying to create a custom widget that allows users to copy and paste a record that has the same attributes and geometry. The copy and paste part of the widget is working but I also want the popup to appear for the newly created feature after it has been added. Originally, the section of code that I am having problems with worked without the popup appearing ...
_copyFeature: function() {
        this.inherited(arguments);
        this.targetLayer.applyEdits([this.featureGraphic], null, null, this._onEditSuccess());
_onEditSuccess: function() {
        this.map.graphics.clear();
        this.map.setExtent(this.map.extent)
        this._postResults("<span style='color:#3ca553;'>Copied " + this.sourceLayer.name + ' Site Number - ' + this.featureGraphic.attributes.site_num + " to " + this.targetLayerName + "</span><br>");
The code I am using to get the popup to appear is below. The problem is, the popup is showing the feature that I am copying not the newly added record.
    this.targetLayer.refresh();
    var query = new Query();
    query.geometry = this.featureGraphic.geometry;
    this.targetLayer.selectFeatures(query, this.targetLayer.SELECTION_NEW);
    this.feature = this.targetLayer.getSelectedFeatures();
    var selectLength = this.feature.length;
    //console.log(selectLength);
    //console.log(this.feature);
    this.feature = this.targetLayer.getSelectedFeatures()[selectLength];
    this.map.infoWindow.setFeatures([this.feature]);
    this.map.infoWindow.show(this.featureGraphic.geometry);
It appears like the edit is not being applied before the _onEditSuccess() is being run. I tried using 'edits-complete' so the _onEditSuccess() would run after the edit was completed but I had no luck. Maybe I am going about this the wrong way. Any suggestions would be appreciated.
RobertScheitlin__GISP
M E,
  OK then it is s scope issue inside the result function. Here is the fix for that:
this.targetLayer.applyEdits([this.featureGraphic], null, null, lang.hitch(this, this._onEditSuccess), lang.hitch(this, this._onEditError));
M E,
    The applyEdits success is returning an object but you are not using it.
    this.targetLayer.applyEdits([this.featureGraphic], null, null, this._onEditSuccess);
_onEditSuccess: function(adds) {
    //adds is an array of FeatureEditResult
    //each FeatureEditResult has an objectId property
    //you can uses these oids in your query
    //loop through the adds array and build an array of ObjectIds
    // for your query.
    var myOids = ....
    query.objectIds = myOids;
    //todo
MarkEastwood
Thanks Robert,
I am still having some issues. When I run console.log(adds), it is returning as undefined. Here is the entire Widget.js file.
define(['dojo/_base/declare',
    'jimu/BaseWidget',
    "esri/layers/FeatureEditResult",
    "esri/symbols/Symbol",
    "esri/symbols/SimpleFillSymbol",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/Color",
    "esri/geometry/Geometry",
    'esri/geometry/Circle',
    'esri/tasks/query',
    'esri/graphic',
    "dijit/form/Select",
    'dojo/_base/html',
    "jimu/PanelManager",
    'dojo/_base/array',
    'dojo/on',
    "dojo/_base/lang",
    'dijit/form/Form',
    "dojo/domReady!"],
  function(declare,
    BaseWidget,
    FeatureEditResult,
    Symbol,
    SimpleFillSymbol,
    SimpleMarkerSymbol,
    SimpleLineSymbol,
    Color,
    Geometry,
    Circle,
    Query,
    Graphic,
    Select,
    html,
    PanelManager,
    Array,
    on,
    lang,
    return declare([BaseWidget], {
      baseClass: 'jimu-widget-vegnetcopyfeatures',
      selectionListener: null,
      selectDijit: null,
      sourceLayer: null,
      targetLayer: null,
      targetLayerName: null,
      isSelected: false,
      featureGraphic: null,
      feature: null,
      onOpen: function() {
        this.map.infoWindow.hide();
        this.map.setInfoWindowOnClick(false);
        this._addListener(this.selectDijit.value);
      startup: function() {
        console.log(this.map);
        this._initSelectDijit();
      _initSelectDijit: function() {
        this.selectDijit = new Select({
          options: this.config.selectOptions
        this.selectDijit.placeAt(this.layerDijit).startup();
        this.own(on(this.selectDijit, "change", lang.hitch(this, function () {
      _addListener: function(value) {
        lang.hitch(this, this._getSourceLayer(value));
        this._getTargetLayer(value);
        if (this.selectionListener != null) {
          this.selectionListener.remove();
        this.selectionListener = this.map.on("click", lang.hitch(this, this._queryLayer));
      _queryLayer: function(evt) {
        // console.log(evt);
        var circle = new Circle({
         center: evt.mapPoint,
         geodesic: true,
         radius: 5,
         radiusUnits: "METERS"
        query.geometry = circle;
        this.sourceLayer.selectFeatures(query, this.sourceLayer.SELECTION_NEW, lang.hitch(this, this._selectionCallback));
      _turnBtnOn: function() {
        html.setStyle(this.execNode, 'display', 'block');
      _turnBtnOff: function() {
        html.setStyle(this.execNode, 'display', 'none');
        isSelected = false;
      _selectionCallback: function() {
        // console.log(this.sourceLayer.getSelectedFeatures());
        if (this.sourceLayer.getSelectedFeatures().length > 0 && this.sourceLayer.visibleAtMapScale == true && this.sourceLayer.visible == true) {
          this.isSelected = true;
          this.feature = this.sourceLayer.getSelectedFeatures()[0];
          //console.log(this.sourceLayer.id);
          lang.hitch(this, this._addGraphicToMap(this.feature));
          this.selectNode.innerHTML = "<strong>1 Feature Selected</strong><br><br>";
          this.selectNode.innerHTML += "<strong>Prework ID</strong> " + this.feature.attributes.prework_id + "<br>";
          if (this.sourceLayer.id === 'Vegetation_Treatment_Status_Archived_6309' || this.sourceLayer.id === 'Vegetation_Treatment_Status_Archived_5826' ){
            this.selectNode.innerHTML += "<strong>Status</strong> " + "Proposed" + "<br>";
          else{
            this.selectNode.innerHTML += "<strong>Status</strong> " + this.feature.attributes.status + "<br>";
          this.selectNode.innerHTML += "<strong>Site Number</strong> " + this.feature.attributes.site_num + "<br>";
          this.selectNode.innerHTML += "<strong>Circuit</strong> " + this.feature.attributes.circuit + "<br>";
          this.selectNode.innerHTML += "<strong>Span From</strong> " + this.feature.attributes.span_from + "<br>";
          this.selectNode.innerHTML += "<strong>Span To</strong> " + this.feature.attributes.span_to + "<br>";
          this.selectNode.innerHTML += "<strong>Treatment Type</strong> " + this.feature.attributes.treatment + "<br>";
          this.selectNode.innerHTML += "<strong>Work Task</strong> " + this.feature.attributes.work_task + "<br>";
          this._turnBtnOn();
        else {
          this.isSelected = false;
          this.selectNode.innerHTML = "<strong>Select a feature to copy.</strong>";
          this._turnBtnOff();
      _addGraphicToMap: function(feature) {
        var geom = feature.geometry;
        var Symbol
        if (feature.geometry.type == "polygon") {
          symbol = new SimpleFillSymbol();
          symbol.setOutline(new SimpleLineSymbol("STYLE_SOLID", new Color("#2afaff"), 4));
        else if (feature.geometry.type == "polyline") {
          symbol = new SimpleLineSymbol("STYLE_SOLID", new Color("#2afaff"), 4);
        else {
          symbol = new SimpleMarkerSymbol("STYLE_CIRCLE", 14, new SimpleLineSymbol("STYLE_SOLID", new Color("#2afaff"), 4));
        if (this.sourceLayer.id === 'Vegetation_Treatment_Status_3561'){
          this.featureGraphic = new Graphic(
            geom,
            symbol,
              "prework_id" : feature.attributes.prework_id,
              "status" : feature.attributes.status,
              //"status" : "Active"
              "site_num" : feature.attributes.site_num,
              "circuit" : feature.attributes.circuit,
              "span_from" : feature.attributes.span_from,
              "span_to" : feature.attributes.span_to,
              "treatment" : feature.attributes.treatment,
              "work_task" : feature.attributes.work_task,
              "consent_obtained" : feature.attributes.consent_obtained,
              "riparian_present" : feature.attributes.riparian_present,
              "condition_assessment" : feature.attributes.condition_assessment,
              "work_priority" : feature.attributes.work_priority,
              "time_hrs" : feature.attributes.time_hrs,
              "number_of_trees" : feature.attributes.number_of_trees,
              "dbhcm" : feature.attributes.dbhcm,
              "height" : feature.attributes.height,
              "target_species" : feature.attributes.target_species,
              "row" : feature.attributes.row,
              "wildlife_tree" : feature.attributes.wildlife_tree,
              "tree_risk" : feature.attributes.tree_risk,
              "merchantable" : feature.attributes.merchantable,
              "timing" : feature.attributes.timing,
              "access" : feature.attributes.access,
              "inspected_by" : feature.attributes.inspected_by,
              "date_inspected" : feature.attributes.date_inspected,
              "comments" : feature.attributes.comments,
              "form8_comments" : feature.attributes.form8_comments,
              "cycle_interval" : feature.attributes.cycle_interval,
              "length_km" : feature.attributes.length_km,
              "last_patrol_date" : feature.attributes.last_patrol_date
        else if (this.sourceLayer.id === 'Vegetation_Treatment_Status_358'){
            geom,
            symbol,
        else if (this.sourceLayer.id === 'Vegetation_Treatment_Status_Archived_5826'){
              geom,
            symbol,
              "prework_id" : 0,
              "status" : 'Proposed',
        else if (this.sourceLayer.id === 'Vegetation_Treatment_Status_Archived_6309'){
            geom,
            symbol,
              "prework_id" : 0,
              // console.log(this.featureGraphic);
              this.map.graphics.add(this.featureGraphic);
      _getSourceLayer: function(value) {
        var ids = this.map.graphicsLayerIds;
        var layer;
        for (i=0; i < ids.length; i++){
          layer = this.map.getLayer(ids[i]);
          if (layer.url == value) {
            this.sourceLayer = layer;
			    //console.log(this.sourceLayer)
      _getTargetLayer: function(value) {
        var layerPair = this.config.layerPair;
        var layer;
        for ( i=0; i < layerPair.length; i++ ) {
          if ( layerPair[i].source == value ) {
            for (j=0; j < ids.length; j++){
              layer = this.map.getLayer(ids[j]);
              if (layer.url == layerPair[i].target) {
                this.targetLayer = layer;
            this.targetLayerName = layerPair[i].name;
        this.targetNode.innerHTML = "Target layer is <strong>" + this.targetLayerName + "</strong>";
        this._turnBtnOff();
      _onEditFail: function(e) {
        this._postResults("<span style='color:#c13333;'>" + e.name + ": " + e.message + "</span><br>");
        //this.targetLayer.refresh();
        //console.log(this.targetLayer);
        //var query = new Query();
        //    query.geometry = this.featureGraphic.geometry;
        console.log(adds)
        //this.targetLayer.selectFeatures(query, this.targetLayer.SELECTION_NEW);
        //this.feature2 = this.targetLayer.getSelectedFeatures();
        //var selectLength = this.feature2.length;
        //console.log(this.feature2);
        //this.feature2 = this.targetLayer.getSelectedFeatures()[selectLength];
        //this.map.infoWindow.setFeatures([this.feature2]);
        //this.map.infoWindow.show(this.featureGraphic.geometry);
      _postResults: function(string) {
        this.resultsNode.innerHTML += string;
        html.setStyle(this.resultsBtn, 'display', 'block');
      _clearResults: function() {
        this.resultsNode.innerHTML = "";
		    this.selectNode.innerHTML = "";
        html.setStyle(this.resultsBtn, 'display', 'none');
		    PanelManager.getInstance().closePanel(this.id + '_panel');
      onClose: function() {
        this.map.setInfoWindowOnClick(true);
        this._turnBtnOff();
        if (this.sourceLayer) {
          this.sourceLayer.clearSelection();
      // onMinimize: function(){
      //   console.log('onMinimize');
      // onMaximize: function(){
      //   console.log('onMaximize');
      // onSignIn: function(credential){
      //   /* jshint unused:false*/
      //   console.log('onSignIn');
      // onSignOut: function(){
      //   console.log('onSignOut');
      // onPositionChange: function(){
      //   console.log('onPositionChange');
      // resize: function(){
      //   console.log('resize');
      //methods to communication between widgets:
M E,
  When you have () behind a function name that function is called immediately.
//you have
//Should be
MarkEastwood
When I remove the (), this._onEditSuccess doesn't run?
M E,
   Then your applyEdits is not successfully running then.
this.targetLayer.applyEdits([this.featureGraphic], null, null, this._onEditSuccess, this._onEditError);
_onEditError: function(err) {
    console.error(err);
MarkEastwood
Thanks Robert,
The error is 'this.inherited is not a function' inside the _onEditSuccess function.
M E,
   Remove this.inherited then as you are not overriding an existing function.
MarkEastwood
Yes, I tried that Robert. Then it just throws an error on the next line.
this.targetLayer.selectFeatures(...);
this.map.infoWindow.setFeatures(...);
this.map.infoWindow.show(...);
this.map.graphics.clear();‍‍‍‍‍‍‍‍
Above was how I was getting the popup to appear (for the wrong feature) previously. Am I not able to use these inside the _onEditSuccess function now?
M E,
