I am using WAB2.7 Dev Edition as a template, and am trying to add a dropdown menu item to the header widget controller element, where all the links are listed. For example (see image below), I would like users to click on the "sample data" link and have a list of N items in a drop-down menu fashion.
Sample Data
Sample Data1 (link)
Sample Data2 (link)
For CSS, I can probably re=use some of the jimu.css style (which one?) but for the functionality, I am looking inside the \themes\FoldableTheme\widgets\HeaderController\Widget.js file:
array.forEach(links, function(link) {
if (link.label.toUpperCase() === 'SAMPLE DATA'){
html.create('a', {
href: link.url,
rel: 'noopener noreferrer',
innerHTML: utils.sanitizeHTML(link.label),
'class': "jimu-link jimu-align-leading jimu-leading-margin1",
style: {
lineHeight: this.height + 'px'
}, this.dynamicLinksNode);}
}, this);
I am aware the customization has to happen here, but I am not sure how to go about it...I would normally add a <div> if I was writing it from scratch, but within the Widget.js, I want to make sure I can do this using the appropriate tags and functions.
Solved! Go to Solution.
Francesco,
This should get you started:
//New function
getMenuPosition: function(myLink){
var position = {
relativeTo: 'map'
var pbox = html.getMarginBox(myLink);
var sbox = {
h: 300,
w: 220
var containerBox = html.getMarginBox(this.map.id);
var top = pbox.t + pbox.h + 16;//put under icon by default
if(top + sbox.h > containerBox.h){
position.bottom = containerBox.h - pbox.t + 1;
}else{
position.top = top;
if(pbox.l + sbox.w > containerBox.w){
position.right = 0;
}else{
position.left = pbox.l + 12;
return position;
// modified function
_createDynamicLinks: function(links) {
if (window.isRTL) {
var _links = [];
_links.unshift(link);
links = _links;
html.empty(this.dynamicLinksNode);
if (link.label.toUpperCase() === 'BLAH BLAH'){
var myLink = html.create('span', {
style: {
lineHeight: this.height + 'px',
cursor: 'pointer'
setTimeout(lang.hitch(this, function(){
var style = utils.getPositionStyle(this.getMenuPosition(myLink));
style.height = 'auto';
style.width = 'auto';
style.display = 'none';
style['padding-right'] = '12px';
style.position = 'absolute';
style['border-radius'] = '2px';
style['z-index'] = '111';
var menu = html.create('div', {
'class': "myMenu jimu-main-background",
style: style
html.create('a', {
href: link.url,
target: '_blank',
innerHTML: utils.sanitizeHTML('Sample Data 1'),
style: {
float: 'left',
clear: 'both'
}, menu);
html.create('a', {
href: link.url,
target: '_blank',
innerHTML: utils.sanitizeHTML('Sample Data 2'),
style: {
float: 'left',
clear: 'both'
}, menu);
on(myLink, 'click', lang.hitch(this, function(){
if(html.getStyle(menu, 'display') === 'block'){
html.setStyle(menu, 'display', 'none');
}else{
html.setStyle(menu, 'display', 'block');
}), 200);
return;
html.create('a', {
href: link.url,
target: '_blank',
style: {
}, this);
Francesco,
//New function
var position = {
relativeTo: 'map'
var sbox = {
h: 300,
w: 220
}else{
position.top = top;
position.right = 0;
}else{
return position;
if (window.isRTL) {
var _links = [];
links = _links;
style: {
cursor: 'pointer'
style: style
html.create('a', {
href: link.url,
target: '_blank',
style: {
float: 'left',
clear: 'both'
}, menu);
html.create('a', {
href: link.url,
target: '_blank',
style: {
float: 'left',
clear: 'both'
}, menu);
}else{
}), 200);
return;
html.create('a', {
href: link.url,
target: '_blank',
style: {
}, this);
Thanks a lot Rob! Would your chunk of code above replace any existing one in the Widget.js or it should be added to it?
Francesco,
If you look at the comments in my code I tell you that.
I see, so the CSS class 'myMenu' you added along with jimu in case I wanted to add a specific custom style to that element?
I have noticed you also used a single link.url as href parameter in both Sample Data 1 and Sample Data 2 <a> link tags...These links will have different URLs to point to, so what do you think is the best way to accommodate that in the config.json file? Would something like this work?
"links": [
"label": "BLAH BLAH",
"url": [url1, url2]
then called in the Widget.js as
href: link.url[0]
href: link.url[1]
