hi Im trying to adjust the example ShowVertex feature action to suite my porposes by adding another feature action to the demo widget and send the name and ID of a feature to the widget.
I have , heres my feature action code
define([
'dojo/_base/declare',
'jimu/BaseFeatureAction',
'jimu/WidgetManager'],
function(declare, BaseFeatureAction, WidgetManager){
var clazz = declare(BaseFeatureAction, {
iconFormat: 'png',
isFeatureSupported: function(featureSet){
return featureSet.features.length > 0 && featureSet.features[0].geometry.type !== 'point';
onExecute: function(featureSet){
WidgetManager.getInstance().triggerWidgetOpen(this.widgetId)
.then(function(myWidget) {
var id
var name
featureSet.features.forEach(function(f){
id = f.id
name = f.name
myWidget.AddtoSelected(name,id);
return clazz;
Im getting a create widget error
when debuggin in chrome I get
init.js:115 TypeError: clazz is not a constructor
at Object.createWidget (WidgetManager.js?wab_dv=2.11:321)
at Object.<anonymous> (WidgetManager.js?wab_dv=2.11:113)
at init.js:64
at l (init.js:108)
at e.then.b.then (init.js:111)
at Object.<anonymous> (WidgetManager.js?wab_dv=2.11:111)
at init.js:64
at l (init.js:108)
at b.extend.then.then.b.then (init.js:111)
at Object.loadWidget (WidgetManager.js?wab_dv=2.11:108) "TypeError: clazz is not a constructor
at Object.createWidget (https://l050736:3344/webappbuilder/apps/11/jimu.js/WidgetManager.js?wab_dv=2.11:321:16)
at Object.<anonymous> (https://l050736:3344/webappbuilder/apps/11/jimu.js/WidgetManager.js?wab_dv=2.11:113:35)
at https://js.arcgis.com/3.27/init.js:64:337
at l (https://js.arcgis.com/3.27/init.js:108:277)
at e.then.b.then (https://js.arcgis.com/3.27/init.js:111:152)
at Object.<anonymous> (https://l050736:3344/webappbuilder/apps/11/jimu.js/WidgetManager.js?wab_dv=2.11:111:47)
at b.extend.then.then.b.then (https://js.arcgis.com/3.27/init.js:111:152)
at Object.loadWidget (https://l050736:3344/webappbuilder/apps/11/jimu.js/WidgetManager.js?wab_dv=2.11:108:12)
rejected at Object.<anonymous> (https://l050736:3344/webappbuilder/apps/11/jimu.js/WidgetManager.js?wab_dv=2.11:126:21)
at Object.<anonymous> (https://l050736:3344/webappbuilder/apps/11/jimu.js/BaseWidgetPanel.js?wab_dv=2.11:76:28)
Error
at Object.loadWidget (https://l050736:3344/webappbuilder/apps/11/jimu.js/WidgetManager.js?wab_dv=2.11:96:17)
at Object.forEach (https://js.arcgis.com/3.27/init.js:71:486)
at Object.loadAllWidgetsInOrder (https://l050736:3344/webappbuilder/apps/11/jimu.js/BaseWidgetPanel.js?wab_dv=2.11:66:13)
at Object.startup (https://l050736:3344/webappbuilder/apps/11/jimu.js/BaseWidgetPanel.js?wab_dv=2.11:55:12)
at Object.d (https://js.arcgis.com/3.27/init.js:198:400)
at Object.startup (https://l050736:3344/webappbuilder/apps/11/jimu.js/OnScreenWidgetPanel.js?wab_dv=2.11:67:14)
at Object.openPanel (https://l050736:3344/webappbuilder/apps/11/jimu.js/PanelManager.js?wab_dv=2.11:152:17)
at Object.<anonymous> (https://l050736:3344/webappbuilder/apps/11/jimu.js/PanelManager.js?wab_dv=2.11:93:16)
at https://js.arcgis.com/3.27/init.js:64:337"
As this error report doesnt mention any of my widget files Im rather confused on where to find the problem, Im assuming its in the feature action as thats where clazz is.
Could someone help point me in the right direction to resolve this error?
James,
Normally this means you have introduced a syntax error in your code, not closed a bracket, forgot a comma, etc. What does your mainifest.json look like? What does your Widget.js look like?
thanks I will take a look at those 2 files for syntax
