Tabs in Enhanced Search Widget
2104
08-15-2014 08:58 AM
MalcolmEchaluce
I'm having a hard time locating where within the code I'm able to change the text shown in the tabs in the Enhanced Search (eSearch) widget.  I've been able to switch the order of the tabnode and its contents but not the tab name.   Can someone point me in the right direction, please?  Thank you!
RobertScheitlin__GISP
Malcolm,
   Almost all of the text in WAB widgets will be controlled by the nls strings.js file.
Malcolm,
MalcolmEchaluce
Thanks for all your help, Robert.  I tried editing the config_Search.json's syntax to have one of the fields show up as an active link.  I'm not sure if I've got the syntax right or if it's just not meant to work with the results to have fields that can be links.  Please see attached and added syntax highlighted.  Your help is much appreciated.
Malcolm,
   Links are not yet implemented in the eSearch Widget or the Query widget in Beta 2. It is something on my todo list. Be sure to make your questions as answered when you get your answer. To do this just click the "Correct Answer" Link on the reply (the one with the little green star).
