Screening widget max record count
2360
04-10-2017 08:41 AM
CCWeedcontrol
I tried using the screening widget from the Environmental Screening with WAB DEV. I down loaded the application and copied the "Screen" folder to my WebAppBuilderForArcGIS\client\stemapp\widgets directory. I started WAB and opened an application and was able to see configure the widget but when i try to run it against the Parcels layer i get the following error, "The maximum record count has been reached for one of more layers". Is there a way around this count error?
I was really excited to see a report widget to incorporate into my applications. What are other options for a report widget, maybe SSRS?
sapnas
I noticed there is an option to increase the max record count in the settings page of the widget. I did not test it but you could increase the count for  "Max feature for analysis" field of the settings page.
CCWeedcontrol
Nobody has tried this widget or any other type of reporting like SSRS?
sapnas
