Modifying panel height results in incorrect position on mobile devices
1706
6
08-29-2019 07:39 AM
MaximeDemers
I want to reduce the height of a widget panel. I did so using a css like
#My_Widget_panel {
  height: 290px !important;
However, when I open the app on a mobile, the panel is not positioned a the the bottom of the screen.
Is there a way to position the panel correctly on mobile device?
RobertScheitlin__GISP
Maxime,
  OK, looking at the Panel.js code yes the height position is ignored. So you would have to change the code in the Panel.js file to fix that.
Maxime,
  Don't adjust the panels height using css. Instead do the height adjustment in code.
MaximeDemers
I have found another of your answers that use the following code in the startup:
      var panel = this.getPanel();
      var pos = panel.position;
      pos.height = 290;
      panel.setPosition(pos);
      panel.panelManager.normalizePanel(panel);
But there is no effect in my app. I also tryed using the resize method
       panel.resize(290, 290);
But no effect neither. Any suggestion? Thank you
Maxime,
  Does this.getPanel() return an object or is it null?
MaximeDemers
Yes, it returns the widget panel object.
I don't know if it's related to my problem, but the widget is not a widgetOnScreen, it's a widget with a button embedded in the header, so in the config.json, it is in the widgetPool property.
MaximeDemers
It's a "themes/FoldableTheme/panels/FoldablePanel/Panel"
It seems the only position that affect the height is the bottom position. Height and width have not effect.
Maxime,
