Measurement widget
3239
8
08-21-2014 07:33 AM
BrianLomas
Is there a way to configure the measurement app so only the length option is available?
RobertScheitlin__GISP
Brian,
  Here is a new version of the widget that allows you to configure in the GUI which buttons are visible:
Brian,
   So you do not want Area or Location buttons?
BrianLomas
No, I'm just needing a basic length measurement. I would really like the output to be along the line as well and not in the measurement window. It's to be used on a phone.
Brain,
   Maybe I am a little dense today then... I am not sure what you are asking about if it is not how to remove the Area and Location buttons...
BrianLomas
Just removing the buttons would work too.
Brian,
BrianLomas
Thanks!
SimonJackson
Am I missing something, but whats the answer? Is there a link in your post thats been stripped out?
Simon,
   If you check threads in your inbox on GeoNet you will not see attachments. If you go to the actual thread then you will see that I provided a attachment that updated widget source code.
Robert
