Listener for layer toggle widget
5236
68
07-20-2018 07:37 AM
MarkLache1
How would I add a listener to Robert's layer toggle widget that would be able to tell what layer is on? I want this so that the info can be passed into Survey123 via custom URL
RobertScheitlin__GISP
Mark,
   Try defining the SERVICE_IS var at the beginning of the file then (line 14):
], function(declare, lang, array, html, query, topic, on, aspect, keys, i18n, dojoConfig, InfoWindow,
  PopupMobile, InfoTemplate, esriRequest, arcgisUtils, Extent, Point, require, jimuUtils,
  LayerInfos, Message, AppStatePopup, MapUrlParamsHandler, AppStateManager, PopupManager, FilterManager) {
  var instance = null,
    clazz = declare(null, {
      appConfig: null,
      mapDivId: '',
      map: null,
      previousInfoWindow: null,
      mobileInfoWindow: null,
      isMobileInfoWindow: false,
      layerInfosObj: null,
      SERVICE_ID: null,
MarkLache1
Robert,
Now its populated with "null"
I don't see how this is happening for you when the exact code I pasted is working fine on my side... Did you copy exactly what I had in my previous post?
MarkLache1
Very weird because its exactly the same. How about I email you my MapManager file?
Mark,
   You do realize that you requested that the Service_ID only be set when a layer is toggled on right? So if you are just clicking on the map and have not used the layertoggle widget to toggle on a layer then the service_id would be null.
MarkLache1
Yes I have tested that. Even when I click the toggle it still returns null. There are 2 layers, one is on and the other is off at start. The toggle just switches the 2 layers.
Here is my MapManager.js
MarkLache1
Brought across the entire js file and no difference. There must be something different with your layers as it works for you but not me.
Mark,
  You need to debug and add breakpoints (degugger;) to the code and check if the this.SERVICE_ID is getting set to something.
MarkLache1
Robert,
Debugging didn't really provide anything (see attached) unless I'm missing something
