Identify Widget (WAB) question - version 1.1.2
6971
10
05-27-2015 08:30 AM
AdamGebhart
Robert Scheitlin, GISP​ and company:
I am configuring the Identify Widget.  I want to have multiple links (as text) in my results window that show information such as Assessor's records and school websites.  I am able to add them, but the links appear on one line (see first image) and without a space between them.  Is there a setting in the configuration window that I need to turn on/off to allow multiple lines?  Or is there something I can do in the apps\#\configs\Identify\config_Identify.json file (second image) to add a line break?  Am I missing something else?
Any help would be appreciated.  Thanks.
RobertScheitlin__GISP
Adam,
   Yes, they should be the same. So the quick fix would be to remove the identify widget from your app and then to save and then add it back,
RebeccaStrauch__GISP
Just a guess here...but will prompt others if I'm wrong...
Do you need another "link"  before the Elementary school?  e.g.
"link": {
"alias": Elementary School",
AdamGebhart
Rebecca Strauch​... thanks for the suggestion.  I've tried that, along with a few other modifications such as adding "\n" in certain spots, and haven't been successful.
Adam,
  Currently the links are inline so that if it is only an icon it will not take up to much vertical space. I will look into adding an option to configure this for text links.
AdamGebhart
Robert,
That makes sense.  Thank you for looking into it further.
Adam
Adam,
   I just checked the code base for the 1.1.2 version of the identify widget and each text link is already placed on it's own line in the widgets results (since I am using a "p" paragraph element). I just tested and it worked fine. Are you sure you are using version 1.1.2?
AdamGebhart
Yes (manfiest.json is below).  If you can tell me where in the code you have the paragraph element set up I can check mine and make sure I have the same code.  I don't recall modifying anything pertaining to that but I do occasionally make an unintended edit.
Adam,
   Sure it is in the list.js file around line 139:
if(link.popuptype === "text"){
            var linkText = domConstruct.toDom("<p><a href='" + link.link + "' target='_blank' title='" + link.alias + "'>" + link.alias + "</a></p>");
            domConstruct.place(linkText, linksDiv, 'before');
            domClass.add(linkText, 'labellink');
          }else{
            var linkImg = domConstruct.toDom("<a href='" + link.link + "' target='_blank' title='" + link.alias + "'><img src='" + link.icon + "' alt='" + link.alias + "' border='0' width='20px' height='20px'></a>");
            domConstruct.place(linkImg, linksDiv);
            domClass.add(linkImg, 'linkIcon');
AdamGebhart
Robert,
I do see that code in client\stemapp\widgets\Identify\List.js.  However, I do not see it in server\apps\#\widgets\Identfiy\List.js.  Should they be the same?
Adam,
