Identify widget display field value as a hyperlink
3879
13
09-13-2018 02:53 PM
HelenZhou
I am trying to customize Robert Scheitlin's identify widget so that so that the identify result shows field value as a hyperlink if the field value is a url.
Here is what I add in the showIdentifyResults module in the widget.js after line 1297 ( I am using widget version 2.7)
     content = content + this.resultFormatString.replace('[attribname]', fld).replace('[attribvalue]', value);
    /////////customize to create a hyper link for a field if the value is a url. Field value start with http or https
      if (value.search("http:") == 0 || value.search("https:") == 0) {
       content.replace(value, '<a href="' + value + '">open link</a>');
The "content" doesn't change. Anybody has done that before?
Helen
Tags (1)
HelenZhou
Hello Robert,
After applying your latest the code suggestion, the content is changed. But the identified panel doesn't render the hyper link - but the source code. Thanks
RobertScheitlin__GISP
Helen,
  in the List.js find and this
attTitle.textContent = attTitle.innerText = attValArr[0].replace(/<[\/]{0,1}(em|EM|strong|STRONG|font|FONT|u|U)[^><]*>/g, "";
and replace with:
attTitle.textContent = attTitle.innerText = attValArr[0].replace(/<[\/]{0,1}(em|EM|strong|STRONG|font|FONT|u|U)[^><]*>/g, "") + ": ";
Then find:
          if (attValArr[1] === 'null') {
            attVal.textContent = attVal.innerText = ": ";
          } else {
            attVal.textContent = attVal.innerText = ": " + attValArr[1].replace(/<[\/]{0,1}(em|EM|strong|STRONG|font|FONT|u|U)[^><]*>/g, "");
          domConstruct.place(attTitle, label);
          domConstruct.place(attVal, label);
          domConstruct.place(label, div);‍‍‍‍‍‍‍‍‍‍‍‍‍‍
and replace with:
          } else {
            var innerCont = domConstruct.toDom(attValArr[1].replace(/<[\/]{0,1}(em|EM|strong|STRONG|font|FONT|u|U)[^><]*>/g, ""));
            domConstruct.place(innerCont, label);
          //domConstruct.place(attTitle, label);
          //domConstruct.place(attVal, label);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
          domConstruct.place(label, div);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In the Widget.js replace your  if statement with this:
if (value.toLowerCase().indexOf("http") > -1) {
  value = "<a href='" + value + "' target='_blank'>" + value + "</a>";
The target _blank is the important part.
HelenZhou
Hello Robert,
I have applied the codes. It works. To make the field value short, I change the code to
                        value = "<a href='" + value + "' target='_blank'>" + "Open Link" + "</a>";
I will do more testing, making sure other functions in the identify widget will stay functional.
Thanks so much for helping.
Helen
Your welcome. Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
