How to draw a line at wanted direction through polygon center and trim it at the 2 opposite polygon borders
1565
06-24-2024 06:23 AM
MichaelLev
In my custom widget I need to draw some parallel lines inside polygon,
so that each of them will not go outside the polygon.
If I'll know how to create and draw a line through the polygon center,
I'll know how to draw all of them.
Tags (3)
MichaelLev
I solved it -
I wrote myself all the code needed, using
1) Draw a line from a point knowing the direction and distance from it
2) the polygon method contains(point)
MichaelLev
I solved it -
