Geometry mismatch with ID results
6046
16
12-11-2018 01:04 PM
WilliamBailey
I am working with wab 2.9 javascript and encountered a strange issue someone may have already dealt with.
Using the simple "ID" functionality, I get the infowindow pop-up from map hosted in AGOL, but the graphic (teal outline) does not match the geometry of the parcel polygon clicked on ???  see pic
At a loss on what and/or why is causing this.Robert Scheitlin, GISP
RobertScheitlin__GISP
I am looking into this. The issue is that your web map has the parcels layer as a ArcGISDynamicMapServiceLayer and not a FeatureLayer Like I was thinking. I will continue to look for a solution.
Is the popup (simple Id) coming from the web map for that layer or are you using some widget to produce that layer?
WilliamBailey
The pop-up is coming from the web map and this odd geometry occurrence does not happen there. (see pic)
William,
   In the jimu/MapManager.js find the _show2DWebMap function and make this change (add line 71-73):
      _show2DWebMap: function(appConfig) {
        //should use appConfig instead of this.appConfig, because appConfig is new.
        // if (appConfig.portalUrl) {
        //   var url = portalUrlUtils.getStandardPortalUrl(appConfig.portalUrl);
        //   agolUtils.arcgisUrl = url + "/sharing/content/items/";
        if(!appConfig.map.mapOptions){
          appConfig.map.mapOptions = {};
        var mapOptions = this._processMapOptions(appConfig.map.mapOptions) || {};
        mapOptions.isZoomSlider = false;
        var webMapPortalUrl = appConfig.map.portalUrl;
        var webMapItemId = appConfig.map.itemId;
        var webMapOptions = {
          mapOptions: mapOptions,
          bingMapsKey: appConfig.bingMapsKey,
          usePopupManager: true
        if(!window.isBuilder && !appConfig.mode && appConfig.map.appProxy &&
            appConfig.map.appProxy.mapItemId === appConfig.map.itemId) {
          var layerMixins = [];
          array.forEach(appConfig.map.appProxy.proxyItems, function(proxyItem){
            if (proxyItem.useProxy && proxyItem.proxyUrl) {
              layerMixins.push({
                url: proxyItem.sourceUrl,
                mixin: {
                  url: proxyItem.proxyUrl
          if(layerMixins.length > 0) {
            webMapOptions.layerMixins = layerMixins;
        var mapDeferred = this._createWebMapRaw(webMapPortalUrl, webMapItemId, this.mapDivId, webMapOptions);
        mapDeferred.then(lang.hitch(this, function(response) {
          var map = response.map;
          //hide the default zoom slider
          map.hideZoomSlider();
          // set default size of infoWindow.
          map.infoWindow.resize(270, 316);
          //var extent;
          map.itemId = appConfig.map.itemId;
          map.itemInfo = response.itemInfo;
          map.webMapResponse = response;
          // enable snapping
          var options = {
            snapKey: keys.copyKey
          map.enableSnapping(options);
          html.setStyle(map.root, 'zIndex', 0);
          map._initialExtent = map.extent;
          this.layerInfosObj = LayerInfos.getInstanceSyncForInit(map, map.itemInfo);
          //save layer's original refreshInterval
          this.layerInfosObj.traversalLayerInfosOfWebmap(lang.hitch(this, function(layerInfo){
            layerInfo.getLayerObject().then(lang.hitch(this, function(layerObject){
              if(layerObject){
                lang.setObject("_wabProperties.originalRefreshinterval", layerObject.refreshInterval, layerObject);
                if(layerObject.type === 'Feature Layer'){
                  layerObject.setAutoGeneralize(false);
            }), lang.hitch(this, function(err){
              console.error("can't get layerObject", err);
          if(appConfig.map.mapRefreshInterval && !appConfig.map.mapRefreshInterval.useWebMapRefreshInterval){
            this._updateRefreshInterval(appConfig.map.mapRefreshInterval);
          this._showUnreachableLayersTitleMessage();
          this._publishMapEvent(map);
          setTimeout(lang.hitch(this, this._checkAppState), 500);
          this._addDataLoadingOnMapUpdate(map);
        }), lang.hitch(this, function(error) {
          console.error(error);
          this._showError(error);
          topic.publish('mapCreatedFailed');
WilliamBailey
No difference, but I never hit that "if" with "breakpoint" at that location
WilliamBailey
It seems to "draw" better when zoomed out some, gets way worse the farther you zoom in (not sure if this helps)
WilliamBailey
using your widget (eSearch) the geometry is perfect
WilliamBailey
I hit the breakpoint in new position, but layerObject.type is undefined.  I do not see "type" in object explorer either.
I also switched to our local GeometryService with no affect.
WilliamBailey
I switched "setAutoGeneralization" to "setNormalization"    no diff
William,
  Sorry I updated the code after I first posted. Can you make sure you are editing the _show2DWebMap function.
