Generate window with metadata information
1031
12-02-2019 11:46 AM
CarolinaAguilar_Aravena
I wanted to know if someone has the code to generate a window with the metadata information. And that this appears in the menu of the layers in the layerlist of an application in WAB?. Want this because when a layer is a map service this menu as "Description" shows the service url, so I would like to consume this information without the need to show the server url. Thanks.
Tags (1)
RobertScheitlin__GISP
Carolina,
   This is the closest thing available to what you are looking for.
https://community.esri.com/thread/188432-enhanced-layer-list-metadata-71717
Carolina,
