Alter size of popup to incorporate multiple images
518
11-27-2019 06:27 AM
joerodmey
Hi all,
Right now I'm trying to include multiple images on a popup in WAB. The images were added using the add popup media option in the AGOL webmap. The images all show up but the user has to click through them using the arrow. What I want is a list of the image such as this:
Can something like this be done in a popup in WAB or AGOL, etc? Just looking for ideas.
CPoynter
Can the functionality you are after be done using HTML tables with images in table cells?
Also possibly use Arcade to show relevant images if records present.
joerodmey
Should be able to with HTML but that's a lot of formatting I was hoping to avoid.
The images are external and not in any feature service so I will be unable to use Arcade.
Thanks for the ideas! I may have to go your HTML route if all else fails.
