Find Task
3454
05-03-2016 02:47 PM
JamesKo
I'm creating my first custom widget using the find task. I can retrieve and display the attributes of the returned records but I'm having issues adding graphics to the map. I've created a graphicsLayer called resultsLayer and added it to the map but I keep getting the following error: TypeError: Cannot read property '_graphicsLayer' of undefined. . Any help is appreciated.
showFindResults: function(results){
   console.log("showFindResults");
   var markerSymbol = symbolJsonUtils.fromJson(this.config.symbols.simplemarkersymbol);
   var lineSymbol = symbolJsonUtils.fromJson(this.config.symbols.simplelinesymbol);
   var polygonSymbol = symbolJsonUtils.fromJson(this.config.symbols.simplefillsymbol);
   var resultItems = [];
   var result, attribs;
   array.forEach(results, function (result){
   var graphic = result.feature;
   attribs = result.feature.attributes;
   resultItems.push("Compkey: " + "<b>" + attribs.COMPKEY + "</b><br>");
   resultItems.push("Unitid: " + "<b>" + attribs.UNITID + "</b><br>");
   resultItems.push("Layer Name: " + "<b>" + result.layerName + "</b><br>");
   resultItems.push("<br>");
   switch (graphic.geometry.type)
   case "point":
     graphic.setSymbol(markerSymbol);
  break;
   case "polyline":
    graphic.setSymbol(lineSymbol);
  break;
   case "polygon":
   graphic.setSymbol(polygonSymbol);
  break;
     this.resultsLayer.add(graphic);
     //this.map.graphics.add(graphic);
RobertScheitlin__GISP
James,
  The problem is a simple scope issue as your array function place its function block in a different scope and it can not find this.resultsLayer.
the fix is to use lang.hitch.
array.forEach(results, lang.hitch(this, function (result){
YueWu1
by Esri Regular Contributor
The error message sounds like you not add the GraphicsLayer | API Reference | ArcGIS API for JavaScript into the Application. Or at least that application doesn't recognize this class "esri/layers/GraphicsLayer"
Would you make sure your widget js file, the dojoLoader has this class and the order is also correct?
For example:
define([
    'dojo/_base/declare',
    'dojo/_base/html',
    'dijit/_WidgetsInTemplateMixin',
    'jimu/BaseWidget',
    'dijit/layout/TabContainer',
    "dijit/layout/ContentPane",
    'jimu/utils',
    'jimu/dijit/Message',
    "dojo/Deferred",
    "dojo/promise/all",
    "esri/layers/GraphicsLayer",
  function(
    declare,
    html,
    _WidgetsInTemplateMixin,
    BaseWidget,
    TabContainer,
    ContentPane,
    utils,
    Message,
    Deferred,
    all,
    GraphicsLayer,
JamesKo
Thanks for your reply. That was one of the first things I checked...Have a look below:
define(['dojo/_base/declare',
  'jimu/BaseWidget',
  'dijit/form/TextBox',
  'dijit/ProgressBar',
  'dojo/on',
  'dojo/_base/array',
  'dojo/_base/lang',
  'dojo/_base/html',
  'esri/layers/GraphicsLayer',
  'esri/graphic',
  'esri/graphicsUtils',
  'esri/tasks/query',
  'esri/tasks/QueryTask',
  'esri/tasks/FindParameters',
  'esri/tasks/FindTask',
  'esri/tasks/FindResult',
  "esri/symbols/jsonUtils",
  'esri/symbols/SimpleMarkerSymbol',
  'esri/symbols/SimpleLineSymbol',
  'esri/symbols/SimpleFillSymbol',
  'esri/Color'],
  function(declare, BaseWidget, _WidgetsInTemplateMixin, TextBox, ProgressBar, on, array, lang, html, GraphicsLayer,
        Graphic, graphicsUtils, Query, QueryTask, FindParameters, FindTask, FindResult, symbolJsonUtils,
    SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color)
James,
JamesKo
Thanks Robert, that was it!
