Anyone using the esearch widget with WAB on a rest service that contains a join. I am unable to get this to work, any thoughts would be appreciated.
Solved! Go to Solution.
Josh,
Sure I have tested layers with joins. Is there any additional info you can share?
Josh,
Lets start with seeing your config_Enhanced Search.json. You can use the advance editor to attach the file once you have zipped it.
Robert,
I attached it to your last reply.
Josh,
So you issue is quite simple the Accounts layer does not return a shape field and thus is causing the widget to error out. Unhide the shape field in your map service and then republish.
Thanks, I completely forgot about that.
Josh,
Glad to help. Don't forget to mark this thread as answered.
