eSearch Widget for WAB
4225
7
12-23-2015 10:56 AM
JoshEllis
Anyone using the esearch widget with WAB on a rest service that contains a join. I am unable to get this to work, any thoughts would be appreciated.
Tags (1)
RobertScheitlin__GISP
Josh,
   Glad to help. Don't forget to mark this thread as answered.
Josh,
   Sure I have tested layers with joins. Is there any additional info you can share?
JoshEllis
Robert,
If I remove the join in the mxd and republish the service I can use the service but if I include the join it just says search failed. Not sure what other info would help you.
Josh,
   Lets start with seeing your config_Enhanced Search.json. You can use the advance editor to attach the file once you have zipped it.
JoshEllis
Robert,
I attached it to your last reply.
Josh,
   So you issue is quite simple the Accounts layer does not return a shape field and thus is causing the widget to error out. Unhide the shape field in your map service and then republish.
JoshEllis
Thanks, I completely forgot about that.
Josh,
