Editing geometry in WAB
2044
01-29-2016 09:12 AM
BillAddison
First time caller, long time fan...
I have a question regarding editing a point feature class in WAB.  This app worked fine in Flex but when I created it in WAB it doesn't seem to allow me to update the geometry of the point.  I select the feature, then drag it to the desired location and all looks fine until I pan the map.  It doesn't seem to stick in the new location.  No errors and no problems when adding a point.  I believe I have all the options turned on and do not have disable geometry updates checked.
Can anyone think of some setting I may have missed?
JordanBaumgardner
If you launch your F12 tools and look at the network traffic - Does it show anything? In particular look at the response back from the server when the update goes in. Often it comes back with a 200 but there is an error in the response JSON.
