e-searsh max number of results
1438
08-05-2019 05:33 AM
SPNIOrganization
Hi ,
I saw there was a similar question 3 years ago, but mine is a little bit different.
I'm using the e-search widget on a layer that is hosted in my portal.
the max number of results I get is 1000.
is there a way to change this through the widget?
I can't find a way to update the max record number of the hosted feature layer in my portal..
the portal version is 10.6.1.
thanks,
Dikla.
RobertScheitlin__GISP
Dikla,
  No there is no setting in the widget for this as this is something that is controlled by ArcGIS server directly.
LeoLiu1
I normally duplicate the search map service and limit the max return count to 10 or 5 and configure it as source of the auto suggestion list for my search box.
