div out of scope
4219
8
04-21-2016 06:10 AM
HelenZhou
I have the following code for a customized widget:
widget html: <div data-dojo-attach-point="moreParcelInfo"></div>
In the Widget.js, I have this code to Query some more information about this parcel
queryLocationInfo: function (parcelID) {
qryTask_SearchID.execute(qry_SearchID, this.showLocationQueryResults, this.qry_SearchIDError);
showLocationQueryResults: function (results) {
     this.moreParcelInfo.innerHTML = resultItems;
In this function, this.moreParcelInfo is undefined. Does it mean this.moreParcelInfo is out of scope of the widget? How to fix it? Thanks
Helen
RobertScheitlin__GISP
Helen,
  Don't forget to mark this question as answered by clicking the "Correct Answer" link on the thread that answered your question.
Helen,
  You use lang.hitch.
qryTask_SearchID.execute(qry_SearchID, this.showLocationQueryResults, lang.hitch(this, this.qry_SearchIDError));
HelenZhou
Thank you so much, Robert. It works. By the way, I really like your customized widgets. They are very useful.
Helen
Helen,
HelenZhou
Robert, I don't know if I need to start a new thread or I can continue to this thread. It is another issue with out of scope.
The error message from Chrome debugging tool: this.showLocationQueryResults is not a function(…)  and this.LocationInfo is undefined too
Can you help? Thanks
Helen
Here is the code:
In Widget.html: <div data-dojo-attach-point="LocationInfo" ></div>
in Widget.js:
          xhr("http://tst-gis4.city.arl/wabdatasupport/SearchAuxiliary.aspx", {
              handleAs: "text",
              query: { parcelid: parcelID },
              method: "POST"
          }).then(function (data) {
             lang.hitch(this, this.showLocationQueryResults(data));
          ------I am able to see the "data"-------------
          ------but the error from Chrome debugging tool: this.showLocationQueryResults is not a function(…)
           --------and this.LocationInfo is undefined too
         }, function (err) {
              // Handle the error condition
              var err;
          }, function (evt) {
              // Handle a progress event from the request if the
              // browser supports XHR2
Helen,
  Anytime you have a function then that functions code block is a different scope then the code block that it is called in so you need to use lang.hitch in front of the function keyword.
HelenZhou
Thank you, Robert, for quick reply.
Yes, I use "lang.hitch(this, this.showLocationQueryResults(data));". But is still not working.
Helen,
  But the line right above that has a function that is not hitched.
HelenZhou
Robert,
I have worked it with the correct syntax:
lang.hitch(this, function(data){
          }),Thanks you so much for help.
