Customize widget title
2470
04-04-2017 11:00 AM
GregRieck
Hello,
Is it possible to center the widget title? Then under the title add an image and the name of the selected feature? I am using this code to add the name of the feature to the title:
this.getPanel().titleLabelNode.innerHTML = NameOfFeature
But it shows up like this:
Widget Title :  NameOfFeature
With no image and not centered or on separate lines. I would like it to display more like this:
Widget Title
IMAGE  NameOfFeature
Greg
sapnas
you have to increase the height of titlelabelnode and push down the container of the widget. The below code should cover it. regarding moving the title towards right add padding to align the text to further right which is again modifying the style of the elements
 this.getPanel().titleLabelNode.style.textAlign = "center";
        this.getPanel().titleLabelNode.style.height = "65px";
        this.getPanel().containerNode.style.top = "70px";
        var nameOfFeature = "test";
        var innerHTML = "<p>widget title</p><p style=\"height:300px;\"><img src=\"widgets/widgetname/images/icon.png\" alt=\"image\" style=\"width:15px;height:15px;\"><font size=\"1\" >" + nameOfFeature + "</font></p>";
        this.getPanel().titleLabelNode.innerHTML = innerHTML;
sapnas
code below should work:
this.getPanel().titleLabelNode.style.textAlign="center"
"<p ><img src=\"widgets/widgetname/images/icon.png\"alt=\"image\" style=\"width:15px;height:15px;\"><font size=\"1\" >NameofFeature</font></p>";
GregRieck
Hello Sapna, thank you for responding to my question. I've tried the above code. I have altered it slightly and this is the results I get.
this.getPanel().titleLabelNode.style.textAlign = "center"; //added semicolon
"<p >Widget Title<br><img src=\"images/app-logo.png\"alt=\"image\" style=\"width:24;height:24;\"><font size=\"2\" >NameofFeature</font></p>";
Added the title of the widget and a new line indicator.
This should accept a variable instead of hard coded text. The feature name will change based on the selected feature.
Center widget title
As you can see the widget header needs to be increased in height to accomodate the extra title. Also, it does not appear to be centered. To me it should be more to the right to be correctly centered.
Thank You,
Greg
sapnas
