Control zoom in WAB
2198
7
11-07-2018 08:39 AM
joerodmey
Is there a way to pass into a zoom level or position into an WAB app via the app URL? Similar to what you can do in Survey123 and Collector.
Also, is there a way to open a particular web map in the WAB app via URL?
RobertScheitlin__GISP
Joe,
  Sure all the url parameters available are cover here:
Use URL parameters—Web AppBuilder for ArcGIS | ArcGIS
Joe,
joerodmey
But my app is stored on my own web server
That does not change a thing.
joerodmey
So if my domain is this: www.example.com and my app is stored at directory /app... i can build my link like this: www.example.com/app&query=census_8491, OBJECTID,1
Is that correct?
Correct
joerodmey
It worked. Had to use ? instead of &
Joe,
  Ah, missed that you had & instead of ?. If you don't know the difference and reasoning for those in the url the ? is always used before the first url parameter and the & is used for the second and greater url parameters.
