Compare side by side widget
5915
6
05-13-2015 03:23 PM
ChadRicks
I am wanting to make a widget that toggles between the standard single map view and a side by side maps with identical extents and zoom levels sort of like in the compare template http://www.arcgis.com/apps/CompareAnalysis/index.html?appid=37e076cb5893405fbd09d774f350fae2 but it would just be an exact copy one on the left and one on the right. I currently have a building floor viewer widget that selects what floor to view and would like to have a side by side screen to see the first floor on the left and second floor on the right.
I'm not sure where to start but i would like have a button or checkbox that would change the page from one map to two and back to one when clicked again.
Any thoughts?
LarryStout
Chad,
I made a side by side overview map for the Flex Viewer.  You can see it here:
Hamilton County Flex Viewer
Look on the right edge of the map for the widget.
I've always intended to do the same for the WAB.  Maybe I could move it up on my list if it's what you are looking for.
Larry
StanMcShinsky
Would something like the swipe widget work?
-Stan
RickeyFight
I like the Idea!
RebeccaStrauch__GISP
The swipe widget Stan refers to is Swipe Plus Widget Version 1.1.3 April 11, 2015
This and a list other custom widgets and resources can be found Web AppBuilder Developer Edition – Customization Resource List
LarryStout
Chad,
Larry
RickeyFight
Larry,
I like it!
ChadRicks
Larry,
That widget would work great for me. I would just configure it to match the zoom level and extent of the main screen. If you make it I would definitely use it.
