Changing the text of the Plan Route (Analysis widget)
2632
6
05-08-2018 07:06 AM
MarijeKootstra
Hello everyone,
I am busy building my webapp in the Web AppBuilder for Arcgis for modeling multi criteria routes for pedestrians.
For solving this problem I am using the 'Plan Route' option in the Analysis widget. However, I would like to adjust the text in the widget. At the moment the widget asks users to specify the maximum number of stops per vehicle. In my case, I would like the widget to state the maximum number of stops per walking route. Is this possible? Do I need to adjust the existing files of the Analysis widget or do I need to create a costum widget?
Thank you!
RobertScheitlin__GISP
Marije,
   That is an esri default bundle string so you have to change it using this code:
    postMixInProperties: function() {
      this.inherited(arguments);
      jsapiBundle.planRoutesTool.maxPtsRoute = "Maximum number of stops per walking route";
      lang.mixin(this.nls, jsapiBundle.analysisTools);
      lang.mixin(this.nls, window.jimuNls.common);
      this.nls.toolNotAvailable = settingBundle.toolNotAvailable;
Marije,
   You would have to modify code in the widget to do that so it requires you to use WAB Developer edition to make those code changes.
MarijeKootstra
Heey Robert,
I do have WAB Developer edition but I cannot find the code in the widgets folder (client > stemapp> widgets). The ‘string’ Javascript file does not contain the text labels I would like to change. However, in the builder folder (client > stemapp > builder > nls) the Javascript file ‘main_en’ does contain the text labels. However I am not sure how I can change this code and if I am even allowed to change this code. If you know more about this I would really like to know.
Marije,
MarijeKootstra
Robert,
Thank you very much. Could you maybe specify in which file I would have to make such changes?
Sorry I forgot that part. Yo need to make the changes I have above in the Widget.js file for the Analysis widget.
MarijeKootstra
Thank you, it works perfectly!
