Analysis (Extract Data) Widget: Where do I save my result?
2339
04-20-2022 07:58 AM
OscarFitzpatrick
I'm trying to draw a polygon and then select the data that intersects it. If I can't do this, I would like to extract the polygon that I have drawn as a shapefile and I will code a script to select by location using arcpy.
I've added a draw widget and an extract data widget in my web map, but I do not have any options in the drop down menu which asks where I would like to save my result. It does not accept a folder path to any of my drives, so I assume that it would like to save the result somewhere online. Does anyone know how I can download the selected layers to the users computer, or failing that, where the tool wants me to save the result?
Any help is appreciated!
BillMoody
I'm experiencing this now.  Did you ever find a solution?  Thanks!
NickRappa
Hi @BillMoody , were you able to resolve this issue? I'm experiencing the same. Thanks
BillMoody
Yes.  I had to go to the portal sharing/rest interface and update the url that the analysis service was pointing to.  Mine was using the internal URL.
