Addresses are not showing in Direction Widget WAB 2.6
4051
11
09-20-2018 03:39 AM
SivaramKrishnan2
Hi
I am creating a Direction Widget in WAB 2.6. There i'm giving input stops but in the route results, i could see latitude and longitudes instead of addresses as shown in the below screenshots.
Please help me to overcome this issue.
Thanks & Regards
Siva
RobertScheitlin__GISP
Siva,
   Are you using your own Network service or esri's?
SivaramKrishnan2
Robert,
Thank you for the response.
We are using our own network service which is deployed in ArcGIS server 10.5.1
Regards
Siva
SivaramKrishnan2
Robert,
Thank you so much for that link.
I have included the below piece of code in my direction widget's locator part.
singleLineFieldName: "SingleLine",
searchTemplate:"${Match_addr}",
localSearchOptions: {
minScale: 300000,
distance: 50000
This is working, but still i'm getting latitude and longitudes for some addresses(i.e stop points).
Thanks & Regards
Siva
Siva,
  It is possible that your service is unable to find an address for that location then. You would have to look at the Network tab and see what the server is returning for that loaction.
SivaramKrishnan2
Thank you Robert,
I checked the network tab of the browser and got this messages.
is there any steps or workaround to overcome this issue ?
Regards
Siva
Siva,
   The error says invalid query parameters. Can you copy the url with the parameters that is being submitted and post here (if you right click on your highlighted request in the image you will get an option to copy the url)?
SivaramKrishnan2
Robert,
please refer the URL's for both success and failure cases.
Failed Coordinates(Not getting address):
https://<My 10.5.1 Server>/arcgis/rest/services/AddressLocator/GeocodeServer/reverseGeocode?outSR=%7B%22wkid%22%3A4326%7D&location=%7B%22x%22%3A77.36622486425071%2C%22y%22%3A28.70099093986658%2C%22spatialReference%22%3A%7B%22wkid%22%3A4326%7D%7D&distance=100&f=json
https://<My 10.5.1 Server>/arcgis/rest/services/AddressLocator/GeocodeServer/reverseGeocode?outSR=%7B%22wkid%22%3A4326%7D&location=%7B%22x%22%3A77.36194183444022%2C%22y%22%3A28.775230123248484%2C%22spatialReference%22%3A%7B%22wkid%22%3A4326%7D%7D&distance=100&f=json
Passed Coordinates(getting the adresses):
https://<My 10.5.1 Server>/arcgis/rest/services/AddressLocator/GeocodeServer/reverseGeocode?outSR=%7B%22wkid%22%3A4326%7D&location=%7B%22x%22%3A77.14707650561374%2C%22y%22%3A28.76309487211875%2C%22spatialReference%22%3A%7B%22wkid%22%3A4326%7D%7D&distance=100&f=json
Thanks & Regards
Siva
Siva,
   The submitted url parameters are the say besides the change to the x and y. It just has to be that you locator is unable to resolve an address for that location. I am not sure what to do.
