How Can I use JS in the Widget.html ?
2485
09-24-2018 12:35 PM
AliAjami-Bakhtyarvand
<a class="twitter-timeline" href="https://twitter.com/TwitterDev?ref_src=twsrc%5Etfw">Tweets by TwitterDev</a>
<script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script>
I was trying to use this code that is with HTML and JS but it does not work.
Could you please help me to use JS in HTML widget ?
Thanks.
GeoprocessamentoCarusoJR
I don't know if you can use script tags but... there's another problem :
You can't have orphan tags in the widget.html
For example, do this :
<div>
</div>
Yes, it does not work, I put script in the lib and upload it on the index.html (head) , then I have this on the source library on my home page when I check debugger. so the html and java code is separate now but still does not work.
My result for use that code and add twitter on lib.
I find solution. I need to add Widget.js without HTML and UI file.
the code is:
define(['dojo/_base/declare', 'jimu/BaseWidget'],
function(declare, BaseWidget){
var TwetterTag = declare(BaseWidget, {
templateString: '<div><a class="twitter-timeline" href="https://twitter.com/TwitterDev?ref_src=twsrc%5Etfw">Tweets by TwitterDev800005</a><script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script></div>' ,
startup: function(){
return TwetterTag;
console.log("This is going to add twitter platfrom into page");
// Attaching jQuery the non-blocking way.
var elmScript = document.createElement('script');
elmScript .src = 'https://platform.twitter.com/widgets.js'; // change file to your jQuery library
elmScript .type = 'text/javascript';
document.getElementsByTagName('head')[0].appendChild( elmScript );
///config manifest.json
"name": "CustomTwitterDemo",
"platform": "HTML",
"version": "1.0",
"wabVersion": "1.0",
"author": "Ali",
"description": "This widget Weather with JQuery and https://weatherwidget.io/",
"copyright": "",
"license": "",
"properties": {
"hasConfig": false,
"hasStyle": false,
"hasLocale": false ,
"hasUIFile": false,
"hasSettingPage": false
