Adding custom widgets to Web AppBuilder
2496
09-07-2023 01:58 PM
shildebrand
Hi everyone,
We have recently deployed ArcGIS Enterprise 10.9.1 and are looking into adding custom widgets to Web AppBuilder.  I found this documentation on how to add custom widgets but am uncertain if we need to install the developer edition in order to do this?  I am not a server administrator, so any suggestions or recommendations you can provide me to forward to our IT staff would be greatly appreciated!
AyanPalit
@shildebrand Review the applicable documentation for Experience Builder: https://doc.arcgis.com/en/experience-builder/11.1/configure-widgets/add-custom-widgets.htm
It follows a similar deployment pattern as WAB widgets.
Ayan Palit | Principal Consultant Esri
AyanPalit
@shildebrand If you have a custom widget and simply want to add to an existing Web App - the referenced documentation will suffice. You should not need WAB developer edition (required if you are developing a new custom widget or modifying/enhancing one).
shildebrand
Thank you, this clarifies the confusion I was having between the two different editions.  Does the same concept apply for experience builder?  I'm guessing you only need the developer edition to create or modifying a custom widget?
AyanPalit
