| CMessage Column | |||||
Hi All,
I have created a custom widget to allow users to customise an application's css without having to edit t...
JonLynch2
02-14-2017
Views
This widget gives a little change compare to the regular swipe widget.
For our users it was important to know which...
ofrig
Views
The purpose of this widget is to provide the user with easy access to basic information about the web map that is bei...
ChristopherSchr
Views
11/14/2017 - Tested with WAB 2.5. Updated default linesymbol drawing to a solid line as export/import as GeoJSON had ...
TomSellsted
11
44
21806
Views
This is a modified save session widget to save session as a local file. IE prompts user where to save file and Chrome...
LefterisKoumis
Views
The organization I work at (NASUVINSA/LURSAREA) is developing the cAAE project (Industry Catalogue of Navarr...
XabierVelasco_E
22823
Views
This is just a simple widget to toggle a configured layer(s) on and off using a button. The layer(s) can be a whole m...
RobertScheitlin
15
181
256580
Views
This is just a simple widget to open a URL. The url can be any valid URL Address. The difference between this and jus...
RobertScheitlin
10
61
197074
Views
Here is a new widget for Web App Builder.
Live Preview Site
Generate isolines polygons which represent the...
AugustoMarchi
06-16-2016
Views
this widget let you jump to point and mark that point.
for my needs, I limit the area the user can go to.
btpbtp
05-29-2016
8060
Views
A new widget for Web App Builder to view your webmaps in photos.
(More about Mapillary for ArcGIS.)
This ver...
JanineYoong1
6
9515
Views
Custom WAB widget uses WMS Nexrad weather services provided by ISU
Updated on 6/24/2019 , spatial reference change...
WilliamPelchat
8
Views
Live Preview Site
Web AppBuilder for ArcGIS | Help - Aloha Threat Zone widget
Links to sample pas files:
SUL...
RobertScheitlin
170581
Views
The SaveSession Widget for ArcGIS Web AppBuilder enables users to save the current map settings into a session and re...
DavidMcCourt
12
114
74443
Views
The ChangeWebMap Widget for ArcGIS Web AppBuilder allows users to switch the map content to another web map.
Using ...
DavidMcCourt
15
13676
Views
The AddLayer Widget for ArcGIS Web AppBuilder allows users to add pre-defined map layers to the current map without h...
DavidMcCourt
17018
Views
Here's a port of my FlexViewer Closest Facility Widget for the Web AppBuilder.
http://www.arcgis.com/home/item.html...
MarkDeaton
8
8
8666
Views
For those of you that don't want the popup to block features on the map or wish you could have selections results inf...
RobertScheitlin
43
584
428813
Views
The ArcGIS Online Webmap Switcher allows users to dynamically switch from a selection of webmaps served out in a deve...
DanielStoelb
Views
Live Preview Site
Web AppBuilder for ArcGIS | Help - eBookmark Widget
Latest enhancements/fixes:
Updated for...
RobertScheitlin
70
198424
Views
