Enhanced Search Widget Version 2.23.1 - 11/22/22
582866
2821
07-14-2014 03:57 PM
Live Preview Site
Web AppBuilder for ArcGIS | Help - Enhanced Search widget
List of the latest enhancements and changes:
  1. Fixed issue with Spatial Relationship settings
Older enhancements or changes
Check the "Older enhancements or changes.txt" in the download for a complete list.
Older Versions
Last 2.21 version
Last 2.17 version
Last 2.13 version
Last 2.12 version
Last 2.11 version
Last 2.9 version
Last 2.7 version
Last 2.6 version
Last 2.5 version
Comments
RobertScheitlin__GISP
@leo_pareja  That is not an option in this widget.
JohnConnor00
Hi there,
Great widget! I do not the see the capability in the dropdown for multiselect (like with checkboxes). Is this possible?
JeremyWolff
Hi Robert,
Thank you for your support and contributions! This widget is great and works really well on my hand! I wanted to know if it was possible to sample from two different elevation layers instead of one and have that represented in the graph? Is it just a matter of changing the geoprocessing service or would that also require to edit the app as well?
EvelynArinaitwe
Occasional Explorer
@RobertScheitlin__GISP  Great job with this widget.
I successfully follow https://gis.calhouncounty.org/WAB/V2.23/widgets/eSearch/widgets/eSearch/help/eSearch_Help.htm to set up my search layers. But now I'd like to add multiple search layers from the main config.json so that when I deploy it to another portal or user, these layers are available, just like you did add the pre-configured layers(Louisville Zoning, Counties..)
I have editted the config.json file and added all my search layer configuration, but the changes donot show up when I add the editted widget. Could you please help? Thanks
DustinGriffin_GISP
New Explorer
Robert - I've used this awesome widget in prior years for different clients (thanks a ton) but for some reason this time I'm not seeing map popups when I click on the result records nor am I seeing attributes in the table.  The table with the correct name appears but without any records.  I tried switching to a service that's actually within the map ensuring attribute table was enabled for it, but that didn't do it either.  Also tried different browsers.  Searched through prior posts to see if anyone has had this issue but couldn't find any similar posts/questions.
SimoneCeccolini1
Hello Robert,
i ask you if it is possible change rendering type of selected features wuen listed il a grid.
I wont to chage standard electric blue of esri with a filled theme .
DarrellConnelly
It looks like the Add Item feature of the Portal Contents tab no longer exists in Portal 11.  Does anyone have any suggestions on how to install an webapp extension in 11?
Any help appreciated.
Nicole_Ueberschär
Hi @DarrellConnelly ,
The Add Item button is now called New item but it should still be there:
DarrellConnelly
Hi @Nicole_Ueberschär
That button does not seem to allow for addition of a webapp widget extension.  Do you see something different?
Nicole_Ueberschär
Sorry, now I got what you are missing. I only always added custom widgets to the developer edition and then published that app including the widgets.
Did you try just uploading it without selecting a category first?
DarrellConnelly
Hi @Nicole_Ueberschär ,
I have tried uploading without selecting a category and the application did not recognize the manifest.
It would be tough to have to deploy webapp developer to install a pre-built extension.
Can I just install webapp developer and push the prebuilt extension to the portal?
Darrell
DavidDas__GISP
Hi Robert,
I ran into a problem with your Enhanced Search Widget 2.23.1 with Web AppBuilder 2.27.
The Widget Configuration Panel does not close after I press the OK button.
How to reproduce the problem
1.
Launch Web AppBuilder 2.27
2.
Create a New Project
3.
Select the Default (2D) Template
4.
Open the Widget Tab
5.
Add a Widget
6.
Add the Enhanced Search Widget 2.23.1
7.
Press the OK button.
The Configuration Window does not close.
Best regards,
David
MManthey_TDS
Occasional Explorer
I am in a challenging position of taking over a GIS position from a more experienced GIS manager of a city as my first GIS job. I have been tasked with fixing a Map created with Web AppBuilder using the enhanced search widget. I have been reading up on it and have figured out how to fix the issues within the search by value. However, I can't seem to figure out how to fix the search by shape issues. I continually receive the search failed pop up box. I am looking for some guidance on how to fix this or where to start. I have been looking through the comments and will continue looking for tips.
Any advice helps, thanks!
Megan
DavidDas__GISP
Hi Megan,
Robert Scheitlin has decided to take a break from the ESRI Community Forums.
I will try my best to help you.
The good news is that Robert’s Enhanced Search Widget version 2.23.1 works flawlessly with Web AppBuilder Developer Edition 2.27.
You can try out all the features in our Historical Aerial Photography App:
https://gis.maricopa.gov/GIO/HistoricalAerial
I have enabled all 4 Tabs in the Enhanced Search Widget.
  • By Shape
  • By Value
  • By Spatial
  • Results
Open the By Value Tab and set your Search Layer = Zip Code
Select Zip Code = 85006 from the drop-down list.
Press Search
The map will zoom to Zip Code 85006.
It will be highlighted in orange.
There could be many reasons why you are getting the “Search failed” error message.
Robert made some changes to his latest version of his Enhanced Search Widget. This means configuration files that were created for earlier versions would no longer work. They would throw the “Search failed” error message.
The solution is to delete the old configuration file and start building a new one from scratch.
It could be other reasons like you are missing the proxy settings in your config.json file.
It could also be that you have not configured your own Geometry Service.
I am including all the steps in this PDF file for you to try:
http://davidapps.net/megan.pdf
You can download this ZIP file which includes Robert's eSearch Widget version 2.23.1 and a copy of a fully configured config.json file.
http://davidapps.net/megan.zip
Best regards,
David Das
MManthey_TDS
Occasional Explorer
Hi @DavidDas__GISP
Thank you for reaching out. Ultimately things had become outdated since the original creator published it and there has not been a lot of updates. After many revisits I decided to start over restructuring the widget and I got it working. Yay!
DavidDas__GISP
Hi Megan,
That is wonderful news!!
I am so glad to hear you have Robert's Enhanced Search Widget running again. This widget has been the  centerpiece of all our Web AppBuilder apps over the past 9 years. We would have loved to see this widget ported to the Experience Builder platform.
Best,
David
DanielMx
Good morning @DavidDas__GISP . Thank you for sharing you historical aerial link, it works flawlesly, for whatever reason robert's sample link never worked for me, looking at your site I notice you have the google street view working - Is that widget available for the community? Daniel.
PS. I hope @RobertScheitlin__GISP is doing OK.
DavidDas__GISP
Hi Daniel,
Sorry for the late response. I must have missed the notification.
Yes, we do have the Google Street View Widget in our WAB version of the Historical Aerials Web App.
https://gis.maricopa.gov/GIO/HistoricalAerial/
Robert Scheitlin made this custom widget.
This is version 2.1.
It needs a “googleapikey” from Google to make this work.
Robert took this down several years ago.
We created an Experience Builder version of the Historical Aerials using EXB Dev Edition 1.12
https://gis.maricopa.gov/GIO/HistoricalAerial/EXB
This one works a lot better!
It does not need a goggleapikey.
All this widget does is capture the centroid of your map and open a separate Google Maps Window where you can run Google Street View and view your surroundings in 2D/3D.
This custom widget was created by Frederic Poliart from ESRI Australia.
I have posted all the details in this thread:
https://community.esri.com/t5/experience-builder-custom-widgets/enhanced-exb-coordinate-widget/m-p/1...
You can download a ZIP file with both these Custom Widgets:
http://davidapps.net/GoogleStreetView.zip
  • StreetView à Custom Widget by Robert for WAB
  • Get-map-coordinates-class à Custom Widget by Frederic Poliart for EXB
Robert is doing fine. He is taking a much needed break.
Robert has supported us all with his collection of Custom Widgets since the FlexViewer was released with many updates, enhancements and bug fixes. He ported them all to the Web AppBuilder and several to the new Experience Builder platform.
I cannot think of how we could have made all our WAB Apps without Robert’s Enhanced Search Widget, Identify Widget, Enhanced Locate Widget, Enhanced Bookmark Widget, Enhanced Basemap Gallery Widget, Popup Panel Widget, to name a few.
This was a monumental task which earned him the MVP Award year after year.
I cannot thank him enough for his programming skills and generous help using all his spare time and weekends.
We hope Robert will join our Community again sometime in the future.
DanielMx
David,
Thank you very much for your helpful and informative response, I could not agree more about Robert, I would not be able to create the websites we have with all the help you guys do. Thank you!
P.S.I woudl give the new widgets a try.
Daniel
ZhujingXia
Robert,
this is very useful widget, do plan to do the similar widget in Experience Builder for developer version?
Zhujing
GISFunctionalGroup
@ZhujingXia  , Have u found any alternative for Enhanced search widget in Experience builder ??
If you find any alternative solution for this widget kindly provide us.
VIPLAW
GIS functional Group
Version history
Last update:
‎11-22-2022 07:31 AM
Updated by:
