Create two widget-controllers in a theme
2742
02-21-2018 08:46 AM
Helenpeng
I would like to create a theme that has two widget-controllers so some widgets can be in a header area and some widgets in a sidebar area. My two widget-controllers (as the HeaderController and SidebarController) can individually work well. When I tried to merge them together, it appears the problem of double the existing widgets (See the screenshot). I wonder if it is possible to create two widget-controllers in one theme. If so, how to make two controllers contain different widgets within two panels.
To make the desired layout, I also tried to customize Tab Theme and moved Search widget in the header area, which is getting what we want (See the second screenshot attached). But I cannot add more widgets in the header area. I think it would be nice to add two widget-controllers in a theme to make the desire layout. I wonder if this would be possible.
I attach my zip files for HeaderController and SidebarController.
Helen
MarkCooper5
Hi
I want to do the same thing as you. Did you ever find out if it were possible?
Thanks
Mark
Helenpeng
Mark,
It has not been figured out yet. I see the similar question in the other community(below). No answer either.
If you find out the solution, please share with us. Thanks.
https://community.esri.com/groups/web-app-builder-custom-widgets
JingchaoZhou
Hi Helen,
Any follow ups on this topic? I am facing the same issues.
Thanks.
