Hi mtnbker1213,
The Details are actually a feature dataset in the same geodatabase, and they are in a group layer in the data view, not the layout view. Their are significantly less features in the detail feature classes, basically just a point, line and polygon feature, but the symbolization is much more extensive so that it can symbolize each feature as any type of feature in the database.
As far as cartographic representations is INFO required for these? how well has that worked for you?
The blow up details you have are awesome to say the least. I understand that the tact you have used is to place the details in the Data View as a feature, so the dashed circle around a detail is a white polygon feature class with a dashed border set above the parcels and behind the various line/point features. The line and point features are a �??dummy�?� feature for visual purposes only, trimmed to length in the polygon and symbolized to match the �??real�?� water features. If I have that right then I applaud the creativity of merging some CAD philosophy with GIS.
Keep up the good work.
