Water and Sewer utility Networks in the same enterprise gdb
1930
06-23-2020 11:51 AM
Z__NahideAydin1
We are trying to run 2 utility networks in same sde: 1 water distribution 1 sewer.
We created the unowner account and used it to deploy for water distribution but when we run the apply asset package tool for sewer network this is the error we are getting:
Running script AssetPackageToUtilityNetwork...
ArcGIS Pro 2.5.1.22081
untools 2.5.1
Executing from ArcGIS Pro, 3 map(s), activeMap = True
Asset Package schema version: 2.4
ERROR 001400: Only the data owner may execute these tools.
Failed to execute (AssetPackageToUtilityNetwork).
We were able ti run stage network to for sewer with unowner account. Our enterprise gdb is on a sql server
MikeMillerGIS
Esri Frequent Contributor
What user is being used in the database connection, make sure it is the owner
Z__NahideAydin1
Hi Michael:
I just saw your reply. Yes we were using the unowner account to connect to sde. I would be perfect if we can run 2 networks on the same database.
Valven
We are moving to the Utility Network. I see myself at this same place in a few weeks. My question is can one network contain a full cycle of water. That is a subnetwork for raw water to treatment plant, then subnetwork for transmission and distribution to the parcel, subnetwork for sewer from the parcel to gravity and force main to the plant, Then a subnetwork for reuse distribution. Hey you never know if you don't ask.
I am interested in this post. Thank you
