Utility Network Analyst: Custom valve isolation
52992
31
10-27-2011 08:59 AM
JamalNUMAN
Legendary Contributor
please, see the attache image that shows my question
i wanted to know whether the ArcGIS 10 includes the very urgent command "Custom valve isolation" as built in tool.
This command SELECT the nearest valve that to be closed in case any ruptures occurs at any point in the pipe net work, and thus this valve must be closed to prevent the follow of water at that point!
do we still to add this command in the VBA?
thank you in advance,
regards
Jamal
Jamal Numan
JamalNUMAN
Hi All,
I’m not sure if this tool is already available out-of-the-box in the ArcGIS 10.5?
Thank you
Best
Jamal
Jamal Numan
Andre_Fenwick
Neat
