Stormwater Data Management vs Stormwater Utility Network
2736
10
06-05-2025 08:14 AM
lfrazeurfw
Looking for discussion around two stormwater models from Esri's solutions. My organization is looking to redesign our stormwater database to conform to esri standards. My boss is intrigued by Esri's Stormwater Data Management solution due to the other esri solutions that work well with that schema design (Green Infrastructure solution, Adopt a Catch Basin, etc). These solutions could be rapidly deployed with data in the Stormwater Data Management model, reducing time spent on custom solutions. However, in maybe 1-2 years I believe they'd like to make the shift to utility network. I will be presenting the SDM solution to my boss when she returns from PTO in 10 days, and plan to discuss UN as well. Do you see benefit in shifting to SDM first even if we may redesign our data to the UN relatively soon after? Is Esri designing/redesigning stormwater solutions that will work better with UN instead of SDM?
LindseyStone
Thanks Patrick.. I must have read the documentation wrong and thought that started at Pro 3.5,  I was hesitant making that jump.
