Accessing the Utility Network
2360
11-16-2017 10:38 AM
JordanMiller4
When and where will the utility network be available to download?
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Jordan,
FYI, the ArcGIS Utility Network Management extension will be part of the ArcGIS Enterprise 10.6 release.
GeoConX Plenary segment info
Hope this helps,
DerekLaw
Hi Jordan,
Hope this helps,
XanderBakker
Beta 2 was just released but it is invite only. To learn more about it: Esri Utility Network Pro
RobertThomson
Does any know if this will be released for ArcGIS Pro independently of Enterprise?  As of now I use the US govt Utility Network Template for storm, water and sanitary which I adapted for use in Canada and have been awaiting geometric network support in ArcGIS Pro.
XanderBakker
The ArcGIS Utility Network Management extension is an extension for ArcGIS Enterprise and will not be available as an extension for ArcGIS Pro only. As part of the extension a lot of functionality will be added to Pro and the rest of the platform. However, if yo do not have Enterprise, you will not be able to use the ArcGIS Utility Network Management extension and the functionality provided to ArcGIS Pro.
